• 04.10.2026, 03:06
Grasshopper
11.8v @100%
Sunday, April 8th 2012, 5:07am
Aquaero 5 Pro (run time 28hrs)
water block (AQ5 temps all <30C)
Fan 1 - DDC T1 (#1)
Fan 2 - 3 * fans
Fan 3 - DDC T1 (#2)
Fan 4 - 6 * fans
Only Fan 3 will provide 12volts @ 100%
bcikota
Sunday, April 8th 2012, 10:03am
Hi Grasshopper,
A small voltage drop is normal for this type of voltage regulator, the higher the load the bigger the voltage drop.
11.8V is quite normal.
Kind regards,
Boris.
Grasshopper
Monday, April 9th 2012, 5:14am
not sure i am quite as accepting Boris,
a $1 12 volt ( ie 7812 ) voltage regulator has no problems maintaing 12 volts at the DDC 1T work load of ~900mA,
is it wrong to expect a $150 fan controller to offer normal voltage range.
after 4weeks delay due to stock and a further 3 weeks wait for German and Aus post, should I not feel just a little let down.
iBeta2
Wednesday, April 11th 2012, 12:16am
is it wrong to expect a $150 fan controller to offer normal voltage range.....
Have you checked the input voltage to the Aquaero? With the cheap regulators, the output will be no more than Vin-0.7V, so there is no way you can put 12V in and get 12V out.
