• 02.09.2026, 16:14
jacenty
Aquarero 5 PRO - connection problem.
Monday, May 28th 2012, 5:47pm
I have a problem with connecting Aquarero via USB. When Aquarero is connected via USB, I see "Unknown Device" in Device Manager. Everything is connected according to the istructions of Aquarero and motherboard. Why? Is it possible that the cause is a faulty USB cable?
Thanks for reply and sorry for my english :)
Tuesday, May 29th 2012, 10:09am
Could be also a problem with Windows, drivers, the mainboard etc.
Maybe you have another PC so you could test it there to see if it makes a difference. This way you can check if the device is faulty or if it is a problem with your PC.
Hybertz
Wednesday, May 30th 2012, 12:44am
Do you have any Razer devices connected? If so try and disconnect them all and see if that helps - I had a problem much like it where my aquasuite wouldn't detect my aquaero until both razer keyboard and mouse was disconnected. When I finally got the aquaero and aquasuite talking I updated the firmware of the aquaero and afterwards I could just plug the razer devices back in without any problems.
This post has been edited 1 times, last edit by "Hybertz" (May 30th 2012, 12:53am)
jacenty
Saturday, June 9th 2012, 6:54pm
It turned out that Aquarero is broken. On the other computer is also not working. Operating System is clean, without drivers other devices. Well, bad luck :(
Monday, June 11th 2012, 12:18pm
Please send it back for a check/repair.
Similar threads
