• 09.10.2026, 16:58
scottmuir424
fan 3 not showing rpm yet still running
Saturday, June 23rd 2012, 4:23am
when in aquasuite 2012 beta 13 firmware 1022 under aquaero 5 fans section have all 4 fans displayed along the top fans 1, 2 & 4 show rotation speed and the voltage functioning correctly fan 3 however show rotation speed at 0 rpm and a voltage of 11.8v. when i go into the settings for fan 3 i can move the sliders and you can see the fan speed up and slow down accordingly but get no rpms from it. ANy ideas
N7SC
Sunday, June 24th 2012, 1:51am
Have you changed the fan that you are using on the AE 5 fan header #3? The problem may be that the fan has lost its rpm reporting capability. Take the fan that is currently connected to the #3 fan rpm connector on the AE 5 (no rpm) and connect that fan to the #4 fan rpm connector, and connect the fan that is currently on the #4 connector (does show rpm) to the #3 connector. If you switch the fans around on the connectors that way, and the software shows zero rpm now on the #4 fan, that means the fan is not reporting its rpm to the AE 5, because it is the same fan that used to be connected to the #3 fan connector when that showed no rpm. But if the software is still not reporting rpm for the #3 fan, with a different fan connected to it, then you have reason to suspect the AE 5 of being defective.
scottmuir424
Monday, June 25th 2012, 2:18am
checked fan in other fan headers and shows up rpms is there anyway to test the unit to see if its faulty and do you know what kind of warranty these units have
Monday, June 25th 2012, 9:42am
If you have a multimeter: do a continuity check on pin 1 + 3 for the faulty channel. If there is continuity, then its surge protection diode is burned and if you are lucky it is the only damaged part. Even if there is no continuity it could be still damaged but this is more complicated to check.
scottmuir424
Wednesday, June 27th 2012, 9:35am
done continuity test and im getting continuity across pins 1+3 so how do i go about getting it repaired
Wednesday, June 27th 2012, 1:46pm
In this case we would need it back for a repair (if possible).
You can send it back to
Aqua Computer GmbH & Co. KG
Gelliehaeuser Str. 1
37130 Gleichen
GERMANY
Since it is very likely that this is a self-inflicted damage we will charge at least the shipping costs back to you.
scottmuir424
Wednesday, June 27th 2012, 2:22pm
probably cheaper just to buy a power adjust 2 since the rest of the unit is working correctly, as far as damage is concerned unit was connected up correct as per instruction manual so what else would cause this to occur
Wednesday, June 27th 2012, 4:27pm
These surge protection diodes become active at a voltage of 6V. In this case they try to convert the overvoltage into thermal power. Since this is a pretty small part this will work only for a pretty short period of time since normally these diodes should only protect the electronics against short surges. The diode can take up to 30.000V for a few nanoseconds. Normally enough to cover bursts like from an electrostatic charge or stress peaks from the PSU.
It is hard to tell what finally caused the damage on your board.
scottmuir424
Thursday, June 28th 2012, 2:22am
if the diode is faulty would the following still be able to occur, when in aquasuite 2012 beta 13 i can go to the fan section select fan 3 go to advanced settings set the rpm down to say 50% and you can hear the fan slowing down to the selected speed, the fan header is functionioning properly just not getting any display thru aquasuite 2012
Thursday, June 28th 2012, 11:25am
Mhh, I am not quite sure about your settings there. Maybe you can provide a screenshot?
scottmuir424
Thursday, June 28th 2012, 11:47am
overview page shows no rpm yet fan still spins
fan controller page allows me to alter the rpm of the fan
the controller page shows the setup of all the fans (fans 1, 2 and 4 working with no issue, fan 3 working but with no display on the overview page
scottmuir424
Thursday, June 28th 2012, 12:19pm
thought i would do an update on the aquasuite software so installed beta 14 version done a firmware update and now fan 3 and fan 2 are down overview page is just all yellow triangles, looks like the software isnt able to support the hardware
Friday, June 29th 2012, 9:03am
Try to do a full reset:
1.) Turn off the PC and remove the standby power if you are using it.
2.) Remove all sensors from the aquaero.
3.) Place four jumpers on the temperature sensor connectors 5 to 8.
4.) Power on the system and after a few seconds you should see a recovery mode screen in the aquaero display.
6.) Turn the PC off and remove the jumpers from the aquaero.
7.) Start the PC and use the latest aquasuite 2012 software to flash the firmware onto the aquaero.
8.) Turn off the PC, connect all sensors etc. again and start the PC.
Similar threads
