• 20.11.2026, 01:27
Psychor
AQ5 Pro (1024; Beta 14) - alarms don't work?
Tuesday, June 26th 2012, 3:56am
I've set alarms (e.g., buzzer & shutdown) to go off when my flow falls below a certain point. You can see the alarms are set but once the flow drops low enough none of the alarms activate. Please advise.
Thank you.
This post has been edited 1 times, last edit by "Psychor" (Jun 26th 2012, 4:12am)
Psychor
Tuesday, June 26th 2012, 4:12am
I did some further testing and instead of trying to trigger "Warning" and "Alarm" based on flow I tried to trigger them based on temperature. The temperature worked. Clearly something is not working properly with the flow "Alarm Configuration."
Tuesday, June 26th 2012, 9:17am
Very strange, we will have a look into that for the next firmware version.
Psychor
Wednesday, June 27th 2012, 10:05pm
Thanks Shoggy. This is one of the major reasons I bought your flow sensor - so I could trigger a shutdown.
Let me know if you guys need me to test anything.
Thursday, June 28th 2012, 11:43am
Maybe an idea: it might be possible that one of the values is interpreted in liter. Could you test if it works when you set the unit to liter.
Of course we will have a look into that but it is our first idea at the moment.
adolfotregosa
Thursday, June 28th 2012, 1:28pm
mine is working in liters and the alarm works , so Shoggy suggestion should work, !! BUT !! you have to set the liter limits on the aquero itself since the aquasuite max value is only 120... ;( :cursing: X(
Shoggy , another bug to be fixed on the next aquasuite :D
Thursday, June 28th 2012, 4:37pm
It's on the list.
Psychor
Friday, June 29th 2012, 6:27am
It's on the list.
Great. Thanks.
ugapug
Tuesday, July 3rd 2012, 3:56am
Any idea when the next version is coming out?
Wednesday, July 4th 2012, 8:54am
Mid July
ugapug
Thursday, July 5th 2012, 4:53am
Cool, thanks.
cc01
Same problem
Sunday, July 8th 2012, 1:45pm
I have the same problem but my sensor is set to litres. Cannot set an alarm with the option "flow falls below limit". If I set it to "flow exceeds limit", it triggers an alarm irrespective of the value I put in for the limit. Does the flow direction through the sensor have anything to do with it? If the 3pin output generates a signal according to the impeller spinning in one direction, would it change the signal and thereby confuse the aquaero if it was spinning in the opposite direction?
Monday, July 9th 2012, 1:22pm
We already found a bug with the different measurement units so this will be also fixed in the next version.
