• 02.10.2026, 02:12
Psychor
Current difference between PA2s?
Tuesday, June 26th 2012, 4:31am
Take a look at the current for "GPU Bottom Fans (x4)." It reads 0.34A. Four of the same fans are run on another PA2 and they report 0.19A. Nothing else is ran on either PA2 but four fans. Any idea why there would be such a discrepancy between the fan sets?
Thanks.
Tuesday, June 26th 2012, 9:06am
The accuracy in the lower end of the possible measurement range is not so good compared to a higher power consumption. Since also both devices use different methods it is just normal and within their tolerance.
