• 20.11.2026, 05:20
Psychor
AQ5 Pro (1024; Beta 14) - lost connection with PA2s
Friday, June 29th 2012, 5:54am
I'm currently using 1 AQ5 Pro and 4 PA2s. Everything has been just fine with this set up for a couple of weeks now.
However, when I returned from work tonight and unlocked my computer all 4 PA2s (which control all my fans) had disappeared from AQ2012 yet the fans connected to the PA2s were still running and red light on each PA2s was still on.
Restarting the PC did not fix anything. I've had this happen with a total of 2 different AQ5s which I've tested in various PC. AC can you please fix this already!?!?!?! :cursing: Why would the AQ5 and PA2s lose connection with one another yet each work perfectly fine?
This post has been edited 5 times, last edit by "Psychor" (Jun 29th 2012, 6:38am)
Psychor
Friday, June 29th 2012, 6:07am
Well I "fixed" the issue. Restarting didn't work but powering down the PC, cutting power to the PSU and then restarting did the trick. This is insane. 8|
This post has been edited 2 times, last edit by "Psychor" (Jun 29th 2012, 6:38am)
Friday, June 29th 2012, 9:08am
The aquabus has been already completely rewritten - high speed and low speed. The update will be inside the next aquasuite which should be available mid July.
Since the aquaero is also powered by USB you can not do a restart of this device by just shutting down the PC, it must be completely off.
impac
aquasuite 2012 release? mid-july?
Monday, July 23rd 2012, 8:01am
Hello Shoggy,
Are we on schedule for a mid-July release of aqua suite ? looking forward to the release, as I too am having "weird" symptoms starting to act up... nothing changed on my side.. powered it on, and it when "wacko"..
thanks,
Patrick
Monday, July 23rd 2012, 1:01pm
Should have been available since last week but unfortunately we experience some problems with the menus of the new mps sensors. I think the new version will be available in two to three days.
Sorry for the delay.
impac
Tuesday, July 24th 2012, 1:50pm
Awesome!! looking forward to the release. Thanks for keeping us informed!
Cheers,
Tuesday, July 24th 2012, 2:48pm
The update will be available today ;)
