• 30.09.2026, 20:01
Rjrolyn
Aquacomputer RGB LED-Lighting Module
Monday, July 30th 2012, 7:06pm
The Blue LED light no longer works since updating to fw 14. I have set it to the lowwst temps amd still the blue light not working. The Green and the Red works fine at the right temps assigned. Has anyone experienced this. If so what is the workaround. Thanks in advance
This post has been edited 1 times, last edit by "Rjrolyn" (Jul 30th 2012, 7:07pm)
cc01
Tuesday, July 31st 2012, 2:47am
Stating the obvious: check that you have a value assigned in Aquasuite for the blue LED.
Also, check that the wire where it joins the LED has not broken loose. I had this problem and resoldered the wire and all was fine. Gently wiggle the wires close to the LED and see if the blue LED flickers. If that is the case, then the wire may have come loose.
Tuesday, July 31st 2012, 2:48pm
At first I would check the LED itself. Just setup a controller with a direct output of 100% and assign the blue LED to it. In this case it MUST work, if this is not the case then you can be sure that the LED is faulty.
