• 20.11.2026, 07:36
StijnDP
Need some extra information about the cables included with products
Thursday, August 16th 2012, 11:16pm
I have the following items on my list
controller: 1x Aquaero 5 XT + 1x faceplate black
controller extra: 3x PA2 ultra + 1x PA2 5.25" mounting frame black
water temp sensor: 3x inline sensor 1x G1/4 ID 1x G1/4 OD
water flow sensor: 1x flow sensor mps 400
led: aq5 RGB led module
Connected hardware will be:
- aq5 xt fan 4 (pwm): swiftech mcp35x2 4pin header (2nd 4pin header of the mcp35x2 will go to 4pin motherboard to give it a signal too)
- aq5 xt fan 3: 6x arctic cooling AF12025
- aq5 xt fan 2: 2x scythe slipstream 14mm 12H
- aq5 xt fan 1: 4x scythe AP15
- aq5 led: RGB led module
- aq5 temp 1-3: 3x inline sensor
- aq5 aquabus low: flow sensor mps 400
- aq5 aquabus high: 3x PA2 daisy chained
--- To each PA2: 8x scythe AP15
So after the info, my questions:
1) The cables needed to daisy chain the PA2's are they included with the PA2? If not, can you provide a link to which cable I need in the ac shop?
2) The cable needed to connect the master PA2 to the aq5, is it included with the PA2 or aq5 xt? If not, can you provide a link to which cable I need in the ac shop?
3) The cable needed to connect the flow sensor mps to the aq5, is it included with the flow sensor or aq5? If not, can you provide a link to which cable I need in the ac shop?
4) Is my understanding of the flow sensor mps 400 correct? The flow sensor mps has an internal temp sensor too. This sensor data is transfered over the aquabus connection together with the flow data. And this aquabus connection can be connected to the aq5 xt 4pin aquabus low connection instead of the old 3pin flow connection.
5) Anything else that is missing from my list which I need?
(I'm not building an airplane, enclosure is a caselabs TH10 with pedestal)
LarryWill729
Friday, August 17th 2012, 1:05am
With that case you are going to need three pin fan extension and y-cables anyway. Just make sure that the y cables for each bank of 8 fans on the PA2s only have the RPM signal from ONE fan going to the PA2. Otherwise you will get weird results.
I would get a waterblock for the Aquero. Phatboy did a similar set up with forced air collong of the Aquero and he had over heating problems. He does have a RAM air cooling fan blowing on the PA2 heat sinks just to make sure they do not over heat. I dont think you will have the same problem, but it never hurts to be ready.
I do NOT think it is a good idea to run a cable from the pump to the AQ5 and the other connecor to the Motherboard. I think it will result in the AQ5 and the Motherboard Both trying to control the pump. Either make sure only the RPM sensor wire from the pump is connected to the motherboard, or run a three pin cable from the Motherboard to the "Tacho" connector on the Aquero, that will provide the MB with a false "Fan RPM" signal that you can set to shut off if an alarm condition occurs. Much safer and easier that way I think.
The MPS sensor only has one connector for Aquabus, so it should go at the opposite end of the daisy chain from the Aquero. The "Low speed Aquabus" connector will not work for the flow meter. I am not sure, but I think the MPS flow sensor can be directly connected to the Aquero Flow header. Good idea to check with AC guys on that.
The Aquero Aquabus connectors are 4 pins, the fourth pin is +5vDC which is not needed for your setup, so only get the three pin cables. If I am counting my fingrs correctly, you should have enough cables included with the equipment to make all the connections between the Aqua Computer pieces, you are on your own for the fans though. I expect you can make it work out just fine with only two 3 pin extension cables to go from the Tacho on the AQ5 and Mother board, and MAYBE from the AQ5 to the pump.
Remember, you have to first connect EACH PA2 to the Motherboard with the USB cable supplied with the AQ5 and set the unit ID to 50, 51 and 52 and update the firmware if necessary. After the unit IDs are set and the firmware is updated, you can remove the USB cable and install the Aquabus. Also, that the PA2 units will not show up in the AquaSuite 2012 b16 software until you connect a fan or temp sensor to it. I think the Aqua suite 2012 software can change PA2 unit IDs if they are connected by USB, but I am not sure. I suggest using the older Aquasuite 4.72 to set those and do the firmware updates. It will also give you a chance to "See" each PA2 requardless of if anything is connected to them. All Aquasuite software is free for downloading anyway, so what the heck. Be careful when mounting the PA2s to the face plate. There should be little plastic washers included in the face plate package, the go on the mounting legs of the center PA2 and the inner legs of the outer PA2s so that everything is equally spaced and lines up correctly.
Also, you will have to go into the Aquero 5 XT menues and change Fan 4 to PWM instead of voltage control. I believe it is Menu->Outputs->Fans->Fan4.
Also, think ahead on your cable management, you are going to need Four 4 pin moles power conectors and all those Aquabus and sensor and fan wires all over the place behind two 5.25 bay devices, and if you chose to use the waterblock, the hoses as well. It will be messy unless you want to splice wires.
Good luck!
AMD FX-8150 OctoCore O.C. 18% to 4.2 GHz on ASUS M5A99X EVO with 16 GB Corsair Dominator W. C. RAM, 2 nVIDIA Geforce 560TI W.C. in SLI, six Western Digital drives for a total of 4.07 TBytes, AquaComputer Aquero 5 Pro, AquaComputer D5 pump, Multiswitch USB, tubemeter and Kyros CPU block. Two coolant loops,CPU & SLI, MB, RAM and AQ5, with two flow meters. Running Windows 7 Professional 64, and using Open Hardware Monitor v0.5.1Beta Aquasuite B16 hardware temps.
Phatboy69
RE: Need some extra information about the cables included with products
Friday, August 17th 2012, 11:11am
Cables Included
Cables Included
Dont know - but would assume since my level meters came with cables too that all their products come with cables. (ask shoggy or wait for him to confirm)
connection.
Dont know - but it probably does as per above. (ask shoggy or wait for him to confirm)
You will definitely need 3pin fan splitters for the fans with only the last fan with RPM wire or custom made cables.
Look at my build log for details on cabling for setup. Every PA2 needs its own power.
There are manuals that ship with the A5 and the PA2s. I think from memory they are in german for the PA2 but you can translate them in google like i did!
The only other thing to be aware of is that each PA2 needs to have a unique address set from 50 to 55 from memory using the older aquasuite software 4.72 while they are individually connected via USB. The USB connection is only needed for initial setup of the PA2 and then they work over the Aquabus cable after that.
I also have a couple of detailed build logs about the A5 and my system and some other useful links.
Aquaero-5-XT-Controller-Installation
Aquaero 5 Custom Sleeved Cables
Updated-pics-finished-Aquaero-5-XT-Installation
My 990x original build including Aquaero 5
My i7 3930K rebuild with Aquaero 5
About aquaero-5-series
Aquaero 5 tips
Aquaero 5 tips II
This post has been edited 1 times, last edit by "Phatboy69" (Aug 17th 2012, 11:21am)
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
StijnDP
Friday, August 17th 2012, 11:41am
I stalked Phatboy69's posts ( :whistling: ) and it seems his problem was only when running pumps from the AQ5? I saw in reviews one PA2 should be able to handle 12-15 scythe AP15 and I plan to use 8 to be safe.
And you're right about the pump cable. I should use the splitter that swiftech provides so that AQ5 gets a 4pin pwn control and the motherboard the 3pin so that it can only read and not control.
Very glad that all the needed cables will be included. I read the descriptions of everything but it becomes confusing with those custom connections and unknown names. It seemed everything had cables to connect to USB headers but not to the AQ5.
My plan was to order an internal USB to external USB too. That way I can test/configure components from any other PC I want (I saw that in other treads on the forum).
Cable management will be terrible (I also have 24hdd's and 6ssd's in the case). But the aq5 and pa2's will be mounted in the TH10 pedestal 5.25" slots. That way I can keep a lot of wiring out of sight and away from airflow. 16 of 24 AP15's, the 14mm fans and the pump will all go inside the pedestal; so cable distance will be short. For the rest I will have to be smart ^^
Hope an AC rep can jump in and tell a bit more about how the new flow meters connect and which cables I would need.
I used Google translate for the manuals but there isn't a download for the new flow meters (mps) yet. I love the simple wiring of the old flow meters, but I dislike that it was a mechanical sensor.
edit
Thanks for joining the thread Phatboy :)
Guess nobody knows about the new flow meters without the manual.
The links are useful. I found some of your threads around the internet but for instance the one with close ups of the PA2 cables is very helpfull.
The aq5 lineup are such fun products to explore. It's equipment like this that makes building the computer as fun as using it :)
This post has been edited 2 times, last edit by "StijnDP" (Aug 17th 2012, 12:05pm)
LarryWill729
Friday, August 17th 2012, 3:35pm
One thing to expand on for you.
The only custom cables AC products use is one for the old style mechanical flow meter to a standard three pin, and the RGB LED.
Everything else, including high and low speed Aquabus is just the industry standard 3 or 4 or 5 pin connectors. The same kind as connect to MotherBoard fan and USB header connectors. You might be thinking of the customized cables mentioned in some other threads, but all of those are for things like fans and short cable lengths. In your case any cables necessary not supplied with AC products are available on line or any good Computer store.
I still think a water block for the Aquero 5 is a good idea in your situation.
StijnDP
Friday, August 17th 2012, 6:22pm
When I looked at the cables they didn't seem to be standard. But now that I look closer I see it. That problem is solved then since I have everything to make my own wires.
Waterblock is something I want to avoid. I don't like wc on fets, memory, hard disks, ...
If it's a problem with the standard heatsink, I have copper heatsinks that I can try. And if that still isn't enough I'll mod a thermalright HR09 onto it ^^
Phatboy69
Saturday, August 18th 2012, 5:11am
The cables for the A5 to PA2 daisy chain connections are not standard cables because they are female to female 3pin cables. But since they come with those cables its not a problem unless you want to run a long cable from the A5 to the 1st PA2. In any case you can cut and lengthen them or make custom ones pretty simply.
Larry is right about the other connectors and cables for fans and sensors though, they are standard pinouts and connections. The only other exception to that is the relay connector and 2pin PWM channels or RGB LED which you need to order from them. The 3pin is for the relay and the 2pin for the PWM switch channels. Note the PWM connectors 1&2 are not for PWM control of devices, they have PWM power supplies that switch on or off to power simple devices like low current leds, lights, fans or to trigger an external relay. Not to confuse this with the 4th channel which can control PWM fans, pumps etc. ;)
I look forward to seeing what you do with the case and all this gear. It certainly is a lot of fun. Im actually itching to do another project myself just to get to play with this stuff again, because once it's in and running it's all automated so there's not much to do once you finish setting it up! I havent changed my A5 setup for more than 6 months and the whole system runs rock solid for me. I now have the confidence to be able to leave my system on overnight because I know if anything strange or dangerous happens my little A5 will just trigger one of the many alarms ive set and shut it down. :) With such a complex system I would never sleep well with out it! You'll love finding out the things you can do with this amazing tech!
The only thing im waiting for now in the Aquasuite software is to be able to export sensor data to a program I run on my Logitech G19 LCD called LCDhost that shows all hardware temps, speeds and the like. Would love to have fan, pump speed and water temps on there too! ;)
Hint Hint Shoggy... ;) This is miles easier to use than the other lcdHype program. It also supports quite a few different LCDs so the aquasuite developers might be able to work with the LCDhost developer to port your LCDhype plugin to LCDHost.
Or worst case make the XML data export compatible with the below.
Dataviewer tool for XML in LCDHost
PS. if the dev team worked on a LCDHost plugin we could actually use it to put all sorts of cool stuff on the A5 screen without having to learn to program in a scripting language thats used for LCDhype! ;)
This post has been edited 2 times, last edit by "Phatboy69" (Aug 18th 2012, 5:28am)
StijnDP
Saturday, August 18th 2012, 11:27am
I'll just go ahead and order the flow meter. Worst case scenario it isn't designed to daisy chain via a PA2 and I have to use the usb header on mobo. I have enough free usb headers :)
And maybe Shoggy will drop in or put the manual online.
Yesterday the first part of my build arrived. Now I can start measuring everything in detail and order all the rest.
:love: :love: :love: http://img824.imageshack.us/img824/609/img1583cm.jpg
Chieftec CA01 --- Caselabs TH10 + pedestal --- ordinary sized ATX case
I've used Lian Li and MountainMods allready, but these guys from Caselabs their level of build quality and customisation is even higher. They have 40years of experience in making enclosures for medical purposes and only 2years ago started making pc enclosures.
This post has been edited 1 times, last edit by "StijnDP" (Aug 18th 2012, 11:28am)
