• 22.11.2026, 21:31
nameless
Aquaero 5 USB protocol
Sunday, August 19th 2012, 11:53pm
It looks like there's no open-source software that works with Aquaero 5 in Linux. I'm trying to modify existing software to support Aquaero 5. I got as far as getting the data packet from the device, but it looks like the packet format has been completely changed and fields are in the wrong order. For example, the packet from Aquaero 4 had temperature sensor values starting at 0x1CC and Aquaero 5 has them starting at 0x67.
I think I can reverse engineer some of the fields to make the device somewhat useful, but it would be nice if some documentation was available, so that I could update the software to parse the whole packet correctly.
Thursday, September 6th 2012, 11:43am
Just wait for the SDK + documentation which should be available later that year.
JinTu
Saturday, September 15th 2012, 7:59am
I second the request for Aquaero 5 documentation for the purpose of adding Linux support (currently looking to make some enhancements to aerotools).
Shoggy, do you have an ETA what month we can expect this?
This post has been edited 1 times, last edit by "JinTu" (Sep 18th 2012, 12:07am)
Monday, September 17th 2012, 1:49pm
Around the end of this year.
We will not offer any Linux tools. Please note that the already existing Linux tools were programed by users.
JinTu
Tuesday, September 18th 2012, 12:16am
Thanks for the clarification. Looking forward to details on the USB protocol.
As with many consumer grade hardware products we Linux users are often left swinging in the breeze support-wise, but with adequate info we make due on our own.
JinTu
Tuesday, December 11th 2012, 7:14am
Hi Shoggy,
Any chance for an early Christmas present? hint, hint ;)
I have made quite a bit of progress on deciphering the contents just by inspecting what my modified version of aerotools returns, but documentation/reference code would make things far easier given the significant differences between the Aquaero 4 and Aquaero 5.
Tuesday, December 11th 2012, 9:32am
Will not be available within this year.
JinTu
Wednesday, December 12th 2012, 8:21am
Bummer... So are you thinking January, or will it likely be later?
Tuesday, December 18th 2012, 9:47am
I can not tell. Also possible that it will be later.
Tuesday, December 18th 2012, 10:26am
We are still working on the SDK for Windows.
I had a look on the overclock forums. The names of the fans/sensors are not in the same report as the data. Its seperated to reduce the amount of data which has to be transfered at any sensor read out. Also the aquaero 5 uses special reports for reading/writing to the external flash memory in the dataflash. It's much more complicated then the aquaero 4 structures as for any dataflash related actions you have to send an request with one report and then you can read out the result, which is the same with the names for the fans and sensors which are also stored in the dataflash.
In general we are asking the aquaero for a memory bump at a specified dataflash address. It's clear that not all areas of the daflash are allowed to read or write but you can damage the memory with a wrong write command. if the aquaero has read the area it can be read out with a USB-report. After that you still need to know about the structure of the memory to allocate the names to the fans/sensors.
JinTu
Tuesday, December 18th 2012, 5:31pm
Thanks Stephan,
This is very useful info!
I am most interested in reading the data out and fully understand the risks of writing to the wrong address. Can you give me a pointer/reference to the (read) report commands for the dataflash and the valid address ranges in which the data lies?
Tuesday, December 18th 2012, 7:17pm
no, not at this moment.
The data protocol to read the flash memory is not easy. when we finished the sdk, a code sample to read memory locations we include into the sdk.
JinTu
Tuesday, December 18th 2012, 8:18pm
Thanks for your reply Sebastian,
Looking forward to the SDK release.
JinTu
Wednesday, December 19th 2012, 8:22pm
Starting to dig into this after seeing the thread over on the main German forum.
From a USB capture on one of my Windows boxes running Aquasuite:
Source code
1
2
3
4
5
6
7
8
9
10
[288 ms] UsbSnoop - FilterDispatchAny(a44ddfd2) : IRP_MJ_INTERNAL_DEVICE_CONTROL
[288 ms] UsbSnoop - FdoHookDispatchInternalIoctl(a44de1ea) : fdo=88bbfe18, Irp=88bd0e70, IRQL=0
[288 ms] >>> URB 6 going down >>>
-- URB_FUNCTION_GET_DESCRIPTOR_FROM_INTERFACE:
 TransferBufferLength = 000000ec
 TransferBuffer = 88ba6430
 TransferBufferMDL = 00000000
 Index = 00000000
 DescriptorType = 00000022 (illegal descriptor type!)
 LanguageId = 00000002
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
[295 ms] UsbSnoop - MyInternalIOCTLCompletion(a44de126) : fido=00000000, Irp=88bd0e70, Context=83ad24d8, IRQL=2
[295 ms] <<< URB 6 coming back <<<
-- URB_FUNCTION_CONTROL_TRANSFER:
 PipeHandle = 88bddb70
 TransferFlags = 0000000b (USBD_TRANSFER_DIRECTION_IN, USBD_SHORT_TRANSFER_OK)
 TransferBufferLength = 000000ac
 TransferBufferMDL = 83708190
 00000000: 06 00 ff 09 01 a1 01 85 01 15 00 26 ff 00 75 08
 00000010: 96 92 02 09 01 81 02 85 03 15 00 26 ff 00 75 08
 00000020: 96 07 00 09 01 81 02 85 04 15 00 26 ff 00 75 08
 00000030: 96 41 08 09 01 91 02 85 05 15 00 26 ff 00 75 08
 00000040: 96 04 00 09 01 91 02 85 06 15 00 26 ff 00 75 08
 00000050: 96 04 00 09 01 91 02 85 07 15 00 26 ff 00 75 08
 00000060: 96 10 00 09 01 91 02 85 08 96 40 08 09 00 b2 02
 00000070: 01 85 0a 15 00 26 ff 00 75 08 96 1b 00 09 01 91
 00000080: 02 85 0b 96 7b 09 09 00 b2 02 01 85 09 15 00 26
 00000090: ff 00 75 08 96 0b 02 09 01 91 02 85 0c 15 00 26
 000000a0: ff 00 75 08 96 0b 02 09 01 81 02 c0
 UrbLink = 00000000
 SetupPacket =
 00000000: 81 06 00 22 02 00 ec 00
This post has been edited 1 times, last edit by "JinTu" (Dec 19th 2012, 8:26pm)
JinTu
Wednesday, December 26th 2012, 7:26am
I discovered this past weekend that the original aerotools author lynix has started a new project for supporting the Aquaero 5 on github by the name of aerotools-ng . The author has chosen to utilize the HID functionality of the Aquaero 5, and the hidraw capabilities of the Linux kernel (removing the need for libusb or any other external dependencies.) Aerotools-ng has a long way to go before it will be as full featured as the original aerotools, but it does appear to be under active development :thumbup:
I have started making some enhancements and have already sent the first of what will likely be many pull requests.
JinTu
Wednesday, January 2nd 2013, 11:24pm
Source code
1
2
3
4
5
6
7
8
9
10
 Index = 00000000
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
 UrbLink = 00000000
 SetupPacket =
Making some progress in getting the reports in Linux. It looks like some of the reports have changed counts since earlier firmware versions compared with drdeath's post on the main German forum. Here is an annotated report descriptor dump from my Aquaero 5XT:
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
6 0 ff (usage page, vendor defined page 1)
9 1    (usage, vendor usage 1)
a1 1 (collection, application)
85 1 (report ID 1)
15 0 (logical min 0)
26 ff 0 (logical max 255)
75 8 (report size 8)
96 92 2 (report count 658)
9 1 (vendor usage 1)
81 2 (input)
85 3 (report ID 3)
96 7 0 (report count 7)
81 2 (input)
85 4 (Report ID 4)
96 41 8 (report count 2113)
91 2 (output)
85 5 (Report ID 5)
96 4 0 (report count 4)
91 2 (output)
85 6 (Report ID 6)
91 2 (output)
85 7 (Report ID 7)
96 10 0 (report count 16)
91 2 (output)
85 8 (Report ID 8)
96 40 8 (report size 2112)
9 0 (usage undefined)
b2 2 1 (feature)
85 a (Report ID 10)
96 1b 0 (report count 27)
91 2 (output)
85 b (Report ID 11)
96 7b 9 (report size 2427)
b2 2 1 (feature)
85 9 (Report ID 9)
96 b 2 (report count 523)
91 2 (output)
85 c (Report ID 12)
81 2 (input)
c0 (end collection)
I have only just gotten started interpreting the report contents, but progress is always a good thing...
JinTu
Wednesday, January 23rd 2013, 3:02am
FYI for anyone interested, lynix and I have been chugging along deciphering the Aquaero 5 HID reports.
We already have a significant portion of (input) report ID 1 (sensor readings) figured out and have added support for everything in aerotools-ng. Progress on the other reports has been slow, but I have the first portion of (feature) report ID 11 (settings) figured out.
JinTu
Tuesday, February 12th 2013, 8:47pm
Thus far lynix and I have managed to locate and add support to aerotools-ng for the following:
HID input report 0x1
  • current time
  • serial number
  • firmware version
  • bootloader version
  • hardware version
  • uptime
  • total time
  • temp sensors
  • fan VRM (amp) temp sensors
  • CPU temperature sensors
  • flow sensors
  • level sensors
  • fan (RPM, duty cycle, voltage, current)
HID feature report 0xB (11)
  • language setting
  • info page settings
  • temperature units setting
  • flow units setting
  • pressure units setting
  • decimal separator setting
  • temperature sensor offset settings
  • fan VRM (amp) temperature sensor offset settings
  • CPU temperature sensor offset settings
  • fan settings (min RPM, max RPM, min duty cycle, max duty cycle, startboost duty cycle, startboost duration, pulses per revolution, control mode, data source, programmable fuse setting)
I also managed to add a few more enhancements to make better use of the sensor data. One big one is exporting the sensor data to SNMP, so you can use your favorite NMS or graphing utility for threshold alarms and graphs. Here are a few sample graphs from my Cacti template using this data:
It certainly does take more time doing development without documentation or references. The Aquaero 5 equivalent of AquaComputer.TranslationClasses.aquaero_Rev4.cs from the SDK or an equivalent header file with the enums would be very handy ;)
Dare I ask again for an ETA on the long awaited SDK?
This post has been edited 1 times, last edit by "JinTu" (Feb 12th 2013, 8:48pm)
JinTu
Friday, July 5th 2013, 11:06pm
Hi folks,
Another Linux user recently sent me a set of captures from USBPcap which yielded a treasure trove of new info for how the Aquaero5 communicates with Aquasuite. Thanks to this info, I have added support for setting software sensor values (via HID report 7) to my master branch of aerotools-ng on github. I am now in the process of adding support for setting the time (via HID report 5), setting device names (via HID report 10), and reading the device names (a combination of HID report 9 and 12).
I also see HID report 6 on the wire, but haven't figured out what it is yet. Some samples of what I have seen:
Source code
1
2
3
06 00 02 00 00
06 00 08 00 20
06 00 09 00 20
Note: the first byte is the report number (06).
Stephan and sebastian can you tell me what HID report 6 is and how it is being used in the examples above?
Monday, July 8th 2013, 9:17am
Do not use Report 6, this report control the device, lock unlock, reset, and other things. When you send wrong data, the device can be corruppted.
