• 17.11.2026, 12:12
BazManDude
Softare Sensors dont' work on Windows 8
Monday, August 20th 2012, 2:39pm
Now I realise that Windows 8 isn't available for general release until the end of October (I'm an MSDN subscriber so have had access to the RTM version since 15th August) but just thought I'd give you guys a heads up that the software sensors don't appear in the AquaSuite beta 16 dialog box i.e. the dialog box displayed when you click "Select Datasource" for a software temperature sensor. The "Aqua Computer Service " is running and no errors seem to be reported the dialog just appears blank except for the OK button.
If anyone else has seen this problem or has any suggestions/solutions please post them.
Thanks
Thursday, September 6th 2012, 11:56am
As long as Windows 8 has not been officially released we will not look into that nor do we test current releases on that platform. When available there will be updates to be compatible to Windows 8 since we already expect this will not be the only problem.
Pictish1
Software Semsor non appearamce
Thursday, September 13th 2012, 6:54pm
I have exactly the same problem using Windows 7 64 bit version which I am trying to figure out.
Thursday, September 13th 2012, 8:36pm
In windows 7 X32/64 the sensors work without problems.
When you have a empty data source window you have to start/configure your sensor source software.
angryB
Sunday, September 16th 2012, 3:22pm
Hello,
Software sensors work for me, I'm using windows 8 pro (also from MSDN), aquasuite 16 x64 and OpenHardwareMonitor 0.51 beta. Screenshot ->
BazManDude
Monday, November 5th 2012, 2:54pm
Hi angryB
Care to post a link to the download you used for OpenHardwareMonitor 0.51 beta :)
Tuesday, November 6th 2012, 7:04am
Similar threads
