You are not logged in.
cc01
This post has been edited 1 times, last edit by "cc01" (Aug 22nd 2012, 1:12pm)
C, 20 above the water temp, you probably need to reseat the HS.Yes, Yes and Yes!!!
After doing further test and with the help of Aqua Computer i think the problem is solved.
Ambient Temp 28,1c
Water temp 41,4
Flow rate 47,6 l/h
CPU temp 68 c
The water temp sensor needed to get recallibrated! (not sure is this is the right spelling, sorry)
There was a huge 5 degree diff between the actual water temp and what the sensor was showing.
No blockage in my system no air (as far as i can tell) and hopefully a good enough pump for the job.
My question to you guys and girls if my current temp ok?
Thank you all for the great feedback. It helped me a lot.
Please let me know is the system looks ok now.
Regards
The CPU temp is with prime or ibt running, or is that an idle temp? If it's idling at 6C, 20 above the water temp, you probably need to reseat the HS.
Yes, Yes and Yes!!!
Ambient Temp 28,1c
Water temp 41,4
Flow rate 47,6 l/h
CPU temp 68 c
Regards
Yes so am i.Glad you got it sorted!!!![]()
How did they re-calibrate the temp sensor?
He told me to put one of the temp sensors in the fluid. It showed the real water temp a good 5 degree lower then the other sensor was showing.
Then i had to put the difference between the 2 in the aquasuit offset for the water temp sensor. That did the trick.
My idle temps are.
Ambient 28.7c
Case Temp inside 31.6c
Watertemp 36c
CPU temp 39c
Flow-rate 44.9 l/h restricted to 50 hz so the pump is really quit.
Fans around 850 rpm
This after a few minutes cool down after converting movies for over nearly 6 hours or so.
I'm not sure is everything is ok now but it all does looks better now.
Please keep the advices coming. I would like to get my rig good now.
chippie
My idle temps are.
Ambient 28.7c
Watertemp 36c
CPU temp 39c
Fans around 850 rpm
cc01
Hey All,
I would like to run something by you guys again.
I pursuit of a silent operating rig i did the following.
I have setup 4 progressieve curve controllers for controlling the fans as follow.
- For the hdd from 30c - 40c
- Air intake 30c - 45c
- Radiator Pull 33c - 45c
- Radiator Push 38c - 45c
So this means that full blast will only happen when the watertemp reaches 45.
I have been stressing the systems by converting 2 movies at the same time using Handbrake and iVI Pro while doing a bunch of other stuff. The highest short peak in watertemp after more than 6 hours straight is 44.1c the fans don't even reach full blast. When only being used normally the watertemp is around 38c.
Any feedback is this sounds good or can i do better?
Regards
This post has been edited 1 times, last edit by "jpmboy" (Aug 24th 2012, 4:00pm)
jpmboyHey All,
Regards
Oops - my post is in the quote. Corrected
Nah - your rig looks real good. In fact, i would bump the OC higher. Is your airplex 360 one of the built-in pump&tank models? Sorry if I missed that in one of your earlier posts. Take a screen shot and post the controller curves...
Was thinking of getting the plug&cool connectors too but i was told the compression fittings are better. Do u have a push / pull combo with the 240? What are the temps ur getting and the rpm of the fans?Fresh- good to know that the 360 keeps your system cool. We have a 240/c600 that manages to cool an sli rig, but with fans high. I'm tempted to get the 360/d5 combo for it. Next build may use the AC "Gigant ".
Btw, I've (we've) been using plug&cool connectors with 10/8 pur tubing. Very easy to work with and flow seems fine. Much easier than barbs or compression fittings and never a leak.
