• 18.11.2026, 03:55
BorisTheSpider
Aquaero MOLEX - 12v only OK????
Friday, August 24th 2012, 11:05pm
I am about to build my external radbox. The aquaero will be in this radbox, so I need to run a Molex extension to it so it can get power from the PC - it would be easiest if I could just run 2 core wire rather than 4. Can anyone here tell me if the aquaero needs the entire Molex power connection including +5v, or can I just run a 2-pin extension using the yellow (+12v) and black (ground) wires????
chippie
Saturday, August 25th 2012, 1:58am
The Aquaero definately needs all 4 connection, the 12V and the 5v. I asked this a while back.
However the PA2's only need the 12v connections.
chippie
Saturday, August 25th 2012, 2:00am
Why not build a small PSU like those used in the Shuttle PC's into the radbox. This would give you much more flexibility.
BorisTheSpider
Saturday, August 25th 2012, 2:11am
Thanks for the replies. I honestly thought this might be a "suck it and see" problem, but it's great that someone has already looked into it.
I did consider building a PSU into the radbox - I have a 3A 12v power brick laying around which would be fine for my pump and fans, however I am concerned with a failure mode where that PSU fails which would turn off my pump and rad fans, and simultaneously turn off the aquaero, hence leaving no atx-break protection in place, so the PC would stay on, with no cooling and no aquaero to detect the issue and protect the PC.
I guess I'll just have to run 4 cores to the radbox - 3 will probably do since I expect the 2 grounds on the Molex plugs are common (haven't tested yet, but I can't see why they wouldn't be).
chippie
Saturday, August 25th 2012, 2:27am
You will have to run both the grounds as one is a 5v and the other a 12v ground.
Depends on how far you want to go with this, if you really do not want any cables between the PC and rad box, you could purchase one of the new flow meters which has a USB connection on it, you can then connect that to your motherboard and set an alarm to shut down your PC if there is no flow. However without a USB connection to your aquaero in the radbox you will not be able to monitor/control anything with the software. If you are going to run a USB connection to the radbox you might as well buy a nice piece of flexible round conduit and run all the cables in that. You could always even use coloured tubing to match the watersooling tubing and run the cables in that so everything matches.
This post has been edited 2 times, last edit by "chippie" (Aug 25th 2012, 2:33am)
BorisTheSpider
Saturday, August 25th 2012, 2:36am
You will have to run both the grounds as on eis a 5v and the other a 12v ground.
Depends on how far you want to go with this, if you really do not want any cables between the PC and rad box, you could purchase one of the new flow meters which has a USB connection on it, you can then connect that to your motherboard and set an alarm to shut down your PC if ther is no flow. However without a USB connection to your aquaero in the radbox you will not be able to monitor/control anything with the software. If you are going to run a USB connection to the radbox you might as well but a nice piece of flexible round conduit and run all the cables in that. You could always even use coloured tubing to match the watersooling tubing and run the cables in that so everything matches.
Odd that the grounds are not common - I would have expected them to both be common with the AC mains ground, or at least common between the two of them? I have actually connected fans across red and yellow before on molex to get 7v, so surely the grounds must be common otherwise I couldn't rely on there being 7v between the two live rails?
I do plan on running USB to the radbox - I have an external->Internal USB cable here ready to go, along with some USB extensions (radbox hoses will be quite long) laying around that I can use for this. I have a flow meter that will connect to the flow meter header on the aquaero (the flow meter will be in the radbox). So my total cables to the radbox from the PC will be:
1. Molex power
2. ATX break
3. USB
I do plan on ATX break for failure modes, eg. no flow, low res level (got a tubemeter), water overheat etc.
No problem really with running however many cables are necessary, I just want to get it down to a minimum and plan it properly so I run only what is really needed.
chippie
Saturday, August 25th 2012, 3:28am
Did some more googling and on some forums they do state they are common so it looks like you can just use one wire. Funny as the pictures I googled showed them clearly marked as seperate 5v and 12v.....
If you are running so many cables to the radbox I would just get a nice piece of sleeving or conduit and run them all inside that. It will look much neater than having a bunch of seperate cables. Guess you are going to do that. If it were me though for the sake of it I would just run all four molex cores.
Similar threads
