• 29.09.2026, 21:57
Digital_Guy
Aquasuite 2012 Beta 16 Issue
Tuesday, September 11th 2012, 3:13am
I have recently re- installed Aquasuite 2012 Beta 16 after installing new SSD. However, this time I notice many additional lines under Temp Sensor (see screen image). When I click on different lines...a different senor type appears. Has anyone seen this before? I tried to uninstall and reinstall Aquasuite and no change.
Digital_Guy has attached the following image:
Tuesday, September 11th 2012, 7:31am
What operating system do you use? The layout looks strange (borders on left navigation).
LarryWill729
Tuesday, September 11th 2012, 7:58am
I have seen similar things in the past. Try re loading your video drivers, then Dot Net.
AMD FX-8150 OctoCore O.C. 18% to 4.2 GHz on ASUS M5A99X EVO with 16 GB Corsair Dominator W. C. RAM, 2 nVIDIA Geforce 560TI W.C. in SLI, six Western Digital drives for a total of 4.07 TBytes, AquaComputer Aquero 5 Pro, AquaComputer D5 pump, Multiswitch USB, tubemeter and Kyros CPU block. Two coolant loops,CPU & SLI, MB, RAM and AQ5, with two flow meters. Running Windows 7 Professional 64, and using Open Hardware Monitor v0.5.1Beta Aquasuite B16 hardware temps.
Digital_Guy
Aquasuite 2012 Beta 16 Issue - Windows 8 Pro and Enterprise
Tuesday, September 11th 2012, 4:16pm
Testing this application under Windows 8 Pro and Enterprise (which use .net 4.5 in base OS). However, I have since found in other posts that this has happened using Windows 7. Am happy to report with the exception of this issue...everything seems to be working fine. :thumbsup:
chippie
Tuesday, September 11th 2012, 5:05pm
AC posted a few days back that Windows 8 is not yet supported so would not think you will have much luck here even though others may have posted about similar issues in Win7.
By that I mean from the AC guys themselves.....
This post has been edited 1 times, last edit by "chippie" (Sep 11th 2012, 5:06pm)
