• 09.10.2026, 02:00
LarryWill729
Multiswitch 1.41 Fw 1.06/OS 1.02
Wednesday, September 12th 2012, 6:52pm
OK, I am now officially upset.
I have MS installed via Aquabus, jumper 5 installed, all others removed.
Useing AS 2012, I can turn on and turn off all 8 power amps, and all 8 LED.
Aquasuite 2012 shows 100% for all 8 power amps, and all 8 LEDs.
NOTHING HAPPENS TO LEDS OR PREVIOUSLY WORKING CCFL!
The Aquaero 5 information page for Multi switcg 1 shows correct status for Power Amp 1-8 and LED 1-9. On the Multi Switch itself, the LED above switch 2 is lit and will not turn off.
I have tried to set the Switch Output and relays to each of the four options, AS2012 and AQ5 show change in Amp and LED state, but no loads are turned on.
I cannot use the Multi Switch as a USB device becasue Aquasuite 4.72 will not run without exiting AS 2012.
I understand AC has other, higher priorities, But I kneed to know that something is being done.
Larry
AMD FX-8150 OctoCore O.C. 18% to 4.2 GHz on ASUS M5A99X EVO with 16 GB Corsair Dominator W. C. RAM, 2 nVIDIA Geforce 560TI W.C. in SLI, six Western Digital drives for a total of 4.07 TBytes, AquaComputer Aquero 5 Pro, AquaComputer D5 pump, Multiswitch USB, tubemeter and Kyros CPU block. Two coolant loops,CPU & SLI, MB, RAM and AQ5, with two flow meters. Running Windows 7 Professional 64, and using Open Hardware Monitor v0.5.1Beta Aquasuite B16 hardware temps.
Thursday, September 13th 2012, 11:14am
To make sure that I got it right: you can switch the channels on and of in the device or software but in reality they are not switched and always on?
LarryWill729
Thursday, September 13th 2012, 4:24pm
To Make sure, yes, I can switch the outputs off and on in the software, or by setpoint controller, and the AQ information screen shows correct status, but in reality they are always off. Except the red LED above button 2. It stays always on.
I have tried with jumper 2 on and off, no effect. I have a jumper on position 5.
LarryWill729
Thursday, September 13th 2012, 9:15pm
Just run a check, I removed J5 and re connected USB. Shut down AS2012 and loaded AS 4.72. All outputs operated normally, test script ran just fine.
From my poimt of view, the Aquaero 5 is jsut not sending the correct commands to the Multi switch for it to operate.
I understand you guys have bigger problems to solve than the Multi Switch. Just tell me that it is on the list of things to be done. Please?
No one except AquaComputer has anything like this accessory, It would be a shame to see it not supported in AS2012.
LarryWill729
Sunday, September 16th 2012, 10:10am
I just re did my system to remove the Aquastream XT and install an AquaComputer D5. I also connected the Tubemeter adapter cable from AC to the Multiswitch, and removed the tubemeter USB cable.
Now I can control the MultiSwitch LED outputs from AS2012. I do not know if the other Amp Outputs work because I removed all of the lights from the MS because it was not working.
What the heck is going on?
slavearm
Wednesday, October 17th 2012, 5:40pm
Check the bus address when connected to aquasuite. Sounds to me like you have conflicting bus addresses. No two devices can have the same aquabus device address. Should be between 50-57 I think.
