You are not logged in.
BorisTheSpider
BorisTheSpider
This post has been edited 1 times, last edit by "BorisTheSpider" (Sep 15th 2012, 1:18pm)
chippie
BorisTheSpider
No, it's not connected with flow through it.Boris, a quick question, is your MPS 40 level sensor connected to its own, private hose to the Res?
If it is connected to ANY hose that has flow through it, the readings will spike due to water flow past the connector for the sensor.
The Delta 40 is intended to measure a difference in pressure, so for use as a level measurement, one side needs to be connected to the top of the Res in open air, and the otherside connected to the bottom of the Res. And neither high or low side can have any flow past the connector. So if you connected the wet side to a "T" connector at the inlet of your pump, it will do exactly what you describe.
For the high flow sensor spiking down to zero, I suspect a wire problem. Try changing the cable.
BorisTheSpider
This post has been edited 2 times, last edit by "BorisTheSpider" (Sep 17th 2012, 12:12pm)
BorisTheSpider
Hi Sebastian,You can move the move the filter speed scroll bar to slower.
BorisTheSpider
This post has been edited 1 times, last edit by "BorisTheSpider" (Sep 17th 2012, 1:56pm)
