• 23.11.2026, 01:01
failariel
aquaero (((urgent))) problem
Thursday, September 20th 2012, 11:13pm
hello.
I purchased a aquaero.
the fact is that I have everything connected and works well ...
but the image goes to the side .. not centered and does not look good.
someone tells me how to fix it.
I have said that may be because my box metal.
I have a xs-pc h2 ;(
Friday, September 21st 2012, 9:21am
Very likely to be a interface problem between the display controller and the main controller. Remove the front cover and unplug the display. You will some pins on the main controller which go into a socket on the display controller. Bend these pins slightly to the side for a ruler for example. This way they should have a proper contact within the socket.
If that does not help: could you provide a photo from the top so we can see the structure with the bolts, distance pieces etc.? Maybe there is something wrong with the assembly.
Also, which variant of the XT do you have?
- display cover completely black with small lines between the buttons
- display cover with stainless steel inserts above the buttons
- display cover completely black without small lines between the buttons
failariel
Saturday, September 22nd 2012, 12:34am
can be contacted by fake?
or that my computer is not properly grounded?
because if I remove the fasteners on the right side where conceta the touch screen and puts him back to outside the computer case if it works well .... the problem now is to screw the box aquaero the image goes crazy
Wednesday, September 26th 2012, 9:46am
As already asked: which variant of the aquaero do you own and maybe you can provide a photo with a view from above so we can see the different parts and how they are assembled.
Similar threads
