You are not logged in.
Nothing would power up afterwards, but after a little cooling off I was able to get the laptop to power back up, but the USB port is totally dead. The PicoPSU power brick had only blown a fuse, and after replacing it, it and the PicoPSU came back to life. Unfortunately, not so for the Aquaero, it won't power up no matter what I do.This post has been edited 1 times, last edit by "JinTu" (Oct 2nd 2012, 9:07am)
BorisTheSpider
Thanks for the comments. Yea, I suspect a ground loop as well.If, as you say, everything was connected correctly, the only thing I can think of that could cause this would be a difference in ground potential between the ground to the laptop/usb, and the ground from the picopsu. I am completely speculating though, and have no knowledge of the internals of the aquaero or how/why this could happen.
Very unfortunate. I hope you manage to find whatever caused it.
Thanks for the info. Since I do not currently measure continuity between the power ground and the USB ground I might have blown a trace and will try bridging the two.The USB GND is connected with the power ground of aquaero. All GND potentials from the aquaero 5 are internal connected.
BorisTheSpider
Unfortunately, the LT doesn't have an IR receiver. Other than that I'm sure you could just fit the screen to an LT.If it ends up being something more, which I fully expect to be the case, would replacing the mainboard on my Aquaero 5XT with the board from an Aquaero 5LT work and maintain the same level of functionality (using the original touchscreen, IR keyboard, etc from the XT)? I'm looking for a lower cost option than buying a completely new XT unless absolutely required.
Thanks for the info. The IR receiver is actually on the LCD daughter board, and all the pictures I have seen make it looks like the LT and XT mainboards are indeed identical. I'm just looking for AC to comment if this is is in fact the case.Unfortunately, the LT doesn't have an IR receiver. Other than that I'm sure you could just fit the screen to an LT.If it ends up being something more, which I fully expect to be the case, would replacing the mainboard on my Aquaero 5XT with the board from an Aquaero 5LT work and maintain the same level of functionality (using the original touchscreen, IR keyboard, etc from the XT)? I'm looking for a lower cost option than buying a completely new XT unless absolutely required.
I'd imagine the PCB is identical. I can't see why you couldn't remove the IR receiver from your XT and solder it on an LT PCB. If you get no definitive response, feel free to send me a close up picture of your IR receiver and I'll take a look at the PCB on my LT and see if it looks like it would fit straight on.
Thanks for the info Shoggy!You can not use the IR on an aquaero 5 LT. Some parts of the IR controller are integrated to the PCB of the display which you do not have. Even by connecting a controller directly it still would not work since the LT does not use any routines for IR, buttons, display and so on.
The problem with the faulty front on your XT can not be fixed by yourself. Please send us an e-mail to get a new front.
Thanks for the reply Shoggy,The damaged part is a surge protection diode. We can try to repair it but we would not exchange that board since it is clearly an overvoltage damage which is not covered by the warranty.
This post has been edited 1 times, last edit by "JinTu" (Oct 9th 2012, 2:54am)
I used the online form on your website for an RMA and received an automated response that it was received from info@aqua-computer.de. Should I also send an e-mail? If so, what address should I send to?I have no e-mail from you. Everything back to yesterday evening has been answered.
Thanks Shoggy,Ah, OK. The RMA form is not read by anyone since it is only an automatic system if you want to send something back to us. You can use the mentioned info address.
