• 11.11.2026, 18:11
pegleg
how do i get my ac flow sensor working
Tuesday, October 9th 2012, 8:28pm
how do u hook the ac flow sensor to the aquastream xt pump.i have it hooked up to my internal usb motherboard how do i get it working this is my pump(http://shop.aquacomputer.de/product_info…roducts_id=1301 this is the ac flow meter or sensor.( http://shop.aquacomputer.de/advanced_sea…s=53129&x=0&y=0how do i get this to work.thanks to all that help.
pegleg has attached the following image:
This post has been edited 2 times, last edit by "pegleg" (Oct 9th 2012, 8:51pm)
Wednesday, October 10th 2012, 10:01am
In aquasuite 4.72 go into the tab pump and flow rate settings. At the end of this screen you will find an option to select how the connector on the pump should work: select flow sensor and set the calibration value to 169.
Go in the menu bar to aquastream XT -> save settings in device. Shut down the PC (must be off) and turn it on again. The flow sensor should work now.
Wednesday, October 10th 2012, 11:25am
You Can't hook it, it shut working on USB and aquasuite 2012
@shoggy
Das ist der Neue Hf, der läst sich nicht mehr an die AS xt anschließen.
This post has been edited 3 times, last edit by "EnigmaG" (Oct 10th 2012, 12:11pm)
Wednesday, October 10th 2012, 12:34pm
Stimmt, gar nicht drauf geachtet. Hab nur flüchtig aus das Bild geschaut :whistling:
He is right :D
pegleg
ac flow sensor
Wednesday, October 10th 2012, 3:48pm
i dont understand you said it shut on usb aquasuite 2012? well that is what i am useing is aquasuite 2012 sorry i didn't say that.did i order the wrong ac flow sensor,i will be ordering the aquaero 5 xt or pro but i dont know what is better?need help can this flow sensor work for now with my pump?
pegleg
Wednesday, October 10th 2012, 4:08pm
well how can i get it working,or if i can.is there some vidoes or some chart to read about this.this is my first time with watercooling
Wednesday, October 10th 2012, 4:29pm
Sorry my English is not good enough to writing this.
If the USB connected it should be in aquasuite 2012 under MPS
This post has been edited 1 times, last edit by "EnigmaG" (Oct 10th 2012, 4:32pm)
pegleg
Wednesday, October 10th 2012, 4:41pm
yes it is there but i dont get no reading like on that chart well the top chart
This post has been edited 1 times, last edit by "pegleg" (Oct 10th 2012, 5:35pm)
Wednesday, October 10th 2012, 4:53pm
1-5
EnigmaG has attached the following image:
This post has been edited 3 times, last edit by "EnigmaG" (Oct 10th 2012, 4:56pm)
Wednesday, October 10th 2012, 5:51pm
looking good
make a new overview page with the flot oder adding it to the existing (Bild)
quod vide: 10. Overview pages aquasuite 2012 in the manual
This post has been edited 2 times, last edit by "EnigmaG" (Oct 10th 2012, 6:06pm)
pegleg
think i got it
Wednesday, October 10th 2012, 7:05pm
here is the overview page tell me if it dont look good enigmag or any buddy else.
Wednesday, October 10th 2012, 7:27pm
i do´t think 2gal/min is OK
it should between 0,1-0,6gal/min with theaquastream xt
pegleg
Wednesday, October 10th 2012, 9:35pm
ok will try to get it there
pegleg
Wednesday, October 10th 2012, 9:36pm
thanks,what would i have to do to get it down to them marks?
This post has been edited 1 times, last edit by "pegleg" (Oct 10th 2012, 9:39pm)
