• 26.11.2026, 00:18
Avathar77
Aqua Computer High-Flow Flow Sensor Reading
Thursday, November 1st 2012, 3:12pm
I got an Aqua Computer High-Flow Flow Sensor connected to my loop and I think the flow is too low!
I have set the calibration value of the flow meter to 159 as I have seen in an article in XS forums.
It is showing the flow as 0.4 gal/min even at setting 5 of the D5 pump! which I think is too low for a loop like mine
My loop consists of
Koolance CPU 370 1.1 block
Koolance HD6970 Full cover block
1 x 480mm Alphacool XT RAD
less than 1 meter of 1/2" ID 3/4" OD tubing
1 x D5 pump
2 x Koolance QDCs(VL4)
it does have 4 x 90 degree angled adaptors.
Temps are good even at full load for long gaming session - CPU does not go above 50C and GPU max is 41C (room temp 22C)
Is there anything else I can try?
Thursday, November 1st 2012, 4:00pm
The correct value is 169 impulses per liter.
The flow rate sounds OK to me. Maybe it could be a bit higher but it is within a realistic range.
tpb211
Thursday, November 1st 2012, 4:12pm
Calibration impulses per liter should be set to 169 not 159. Hope this helps, Other ideas to increase flow would be to reduce or eliminate 90's [use45's if possible], consider adding a second d5 in a dual top if flow is still to low for your liking. This would also give you redundancy if one pump fails.
BorisTheSpider
Sunday, November 11th 2012, 8:52pm
I'm curious about this calibration number, because Martin tested and found that with 1/2" ID barbs and hoses, 158 was very close to a reference flow-meter: http://martinsliquidlab.org/2012/01/21/a…sensor-meter/6/
If I should be using 169 instead, I'd be interested to know why - it's not a big deal, and the difference in readings will be small, but I haven't seen anything to suggest that Martins testing wasn't accurate, so for now I'm sticking with 158.
mandrix
Tuesday, November 13th 2012, 1:43pm
That seems like a pretty low flow number. I haven't hooked any D5's to a flow sensor though, I'm using a MCP35x.
I have all 7/16" ID tubing, guessing 4-5 foot
2xUT60 480mm rads in pedestal (hence the amount of tubing)
cpu block
2xgpu blocks
6x 45's & 3x90"s & 1x5 way "snake" (all rotaries except the drain line)
169 calibration setting for the high flow sensor
my max flow is around 1.2-1.3 gpm.
Just based on past experience with D5's I would think you would get more than 0.4gpm. But that is only a guess. Can you beg, borrow or steal another D5 and stick in the loop and see what 2xD5's does?
tpb211
Tuesday, November 13th 2012, 1:58pm
Hi Boris,
I recently read the same article and it made me think of this post as well. After reading martins post using 1/2" ID I would be inclined to use the 158 setting as well. I intend to run a similiar test on both of my loops and come up with a calibration value for my particular system. I will share the results when done. I am also using 1/2" ID tubing.
Avathar77
Wednesday, November 14th 2012, 2:45am
cpu block
2xgpu blocks
From what I was told in other forums as well I should expect close to or even over 1GPM! :cursing:
I am going to swap the D5 to my DDC 18W and see how it does.
I don't have another D5 but I can always order one and see how it goes.
Jakusonfire
Friday, November 16th 2012, 12:54pm
The problem is more than likely the QDC's ... they are by far the most restrictive part of your loop.
Personally I would do away with them because although they are convenient they are just too degrading to performance.
BorisTheSpider
Saturday, November 17th 2012, 8:08pm
It suprises me that you'd say that since VL4s are at the very non-restrictive end of QDCs, and in general I don't think they are that bad - http://skinneelabs.com/quick-disconnect-roundup/ gives some numbers. I'm really quite suprised the OP has such low flow with a D5, but I can't see anything in the loop to cause it, so I guess either that's just the performance of a single D5 through a typical loop, or there is something wrong with the pump - OP, have you tried the DDC yet?
I think people worry too much about flow though, although 0.4 does seem low, the OP has great component temperatures so it goes to show you don't actually need a lot of flow.
markspend01
Friday, July 5th 2013, 9:06pm
Hey Boris well i think that the information which you provide about OP temperature is brilliant.Thanks!!
Grasshopper
Saturday, July 6th 2013, 6:48am
Have similar flow from DDC pump (10W), with similar setup. Putting second DDC in series only increases it to 0.6gpm.
This post has been edited 1 times, last edit by "Grasshopper" (Jul 6th 2013, 6:51am)
cc01
Sunday, July 7th 2013, 12:04pm
Does your D5 have a tacho output? If so could you check the speed of the pump? At 12V on setting 5 the speed is around 5500rpm if my memory serves me correctly.
This post has been edited 2 times, last edit by "cc01" (Jul 7th 2013, 12:12pm)
cpachris
Sunday, July 7th 2013, 3:39pm
My D5's get up to 4,800 rpm on full speed.
mandrix
Sunday, July 7th 2013, 4:27pm
Yep, my pwm D5 is about the same.
Jakusonfire
Monday, July 8th 2013, 12:06pm
With a single D5 pump running through a stopped D5, an EK supremacy, an FC 7970 GPU block, an Alphacool XT45 360 and ST30 240 with a bunch of 45's and 90's I'm getting 3.9 LPM
