• 11.11.2026, 03:24
Psychor
AquaComputer MPS Flow Sensor 400 & Temp. Sensor?
Monday, November 5th 2012, 6:20am
Questions:
(1) Can the Aquabus cable (4-pin) used for the prior generation flow sensor be used with the MPS 400?
(2) Once the MPS is connected to the AQ5 via the Aquabus 4-pin cable do I also need to attach a cable to measure temperature? If so where can I buy this cable female to female 2-pin cable?
Thanks.
Monday, November 5th 2012, 11:23am
1.) I guess you confuse something here. There is only one 4-pin aquabus cable available. If you mean the high flow sensor (without USB/aquabus), it is using a 3-pin cable which is incompatible to the aquabus because of a different pin-layout and another plug on one end.
2.) There is no cable necessary. A sensor is already integrated to the mps.
Psychor
Monday, November 5th 2012, 5:40pm
Thanks Shoggy but then what is the "TEMP" port on the MPS for? I thought another cable had to be run from that to the AQ5?
Tuesday, November 6th 2012, 8:57am
You can connect an additional sensor there. The only connection to the aquaero is the aquabus.
Psychor
Wednesday, November 7th 2012, 12:52am
Great. Thanks Shoggy.
