• 09.10.2026, 23:36
WraithGTO
AQUAGRATIX HD 7970 and Sapphire Dual X 7970 compatability
Sunday, November 11th 2012, 11:43am
Gday
I was looking at buying 2 of the AQUAGRATIX HD 7970 water blocks, but I am not sure if they will fit my Sapphire 7970 cards
Does anyone know if the AQUAGRATIX HD 7970 will fit a Sapphire HD 7970 Dual X OC . It has a SKU 11197-03-40G.
I believe it is Similar to a reference card but with a few slight changes. eg there is a extra row of caps to the rear of the card .
Here is a link to the Sapphire Card
http://www.rwlabs.com/article.php?cat=&id=708&pagenumber=5
Cheers
Monday, November 12th 2012, 9:40am
If you card looks like the one from the mentioned link, then it will not work since this card has a different layout.
WraithGTO
Monday, November 12th 2012, 2:56pm
Thanks for the info Shoggy.
Can you tell me what and where please on the 7970 DualX OC Blue PCB variant. That will make the AC block not fit please.
Cheers
Tuesday, November 13th 2012, 12:20pm
Just compare your card with the photo of the card in our shop and you will see a lot of differences. That is nothing that you could modify.
Jakusonfire
Friday, November 16th 2012, 12:50pm
This thread explains the problem. There are two versions of this card.
http://forums.overclockers.com.au/showthread.php?t=1059050
This post has been edited 1 times, last edit by "Jakusonfire" (Nov 16th 2012, 12:51pm)
