• 17.11.2026, 03:23
cristian.ticu
Advice on choosing the right Mps Flowmeter
Monday, November 12th 2012, 3:00pm
I want to change my current hi-flow meters with the new ,no impeller Mps ones. only,this time I find it a bit hard to chose them ; first I have four Hi-flow sensors ,all of them in the same configuration : connected on a reservoir using a straight nipple ,but on the out port ,I have 90 degrees curves (cube type) followed straightaway by a 45 degrees connector on 19/13 tygon tubing. I understand that the Mps sensors are not too fond of curved fittings. with the Mps sensors,can I use the same configuration?
my flow ,right now is, on two sensors 120 to 150 l/h ,on the other two 220 to 250 l/h .what sensors do I need?
Tuesday, November 13th 2012, 12:22pm
You will have to use the mps flow 400 because the mps flow 200 will not read values above 200 l/h.
