• 30.09.2026, 16:36
zdenek
New version problem with two Aquaero's 5 pro
Friday, November 16th 2012, 2:23pm
after install of new version (from latest beta 16) I have problem with working with two aquaeros together. With one all is ok. Is there any problem with it.
Appliaction raises error: system.nullreferenceexception (deviceaccess).
This post has been edited 1 times, last edit by "zdenek" (Nov 16th 2012, 2:37pm)
zdenek
Tuesday, November 20th 2012, 10:51am
Is it my problem only? I can not monitor Aquaeros now.
Tuesday, November 20th 2012, 11:02am
Reset your aquaero to factory defaults.
then connect only one aquaero to your system and update it.
connect the other and update.
now you can use both aquaero 5.
zdenek
Tuesday, November 20th 2012, 12:10pm
I do upgrade this way. I will try to repeat steps again. Maybe I have missed something.
zdenek
Tuesday, November 20th 2012, 12:31pm
All done, but no progress. Service and Appliaction crashes when both aquaeros connected to usb.
Event log for service:
Application: AquaComputerService.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an internal error in the .NET Runtime at IP 792F0197 (79140000) with exit code 80131506.
This post has been edited 1 times, last edit by "zdenek" (Nov 20th 2012, 12:35pm)
Tuesday, November 20th 2012, 12:50pm
it is running when you connect only one aquaero?
zdenek
Tuesday, November 20th 2012, 12:59pm
Yes. If only one aquaero (regardless of which one) is connected all works ok.
Tuesday, November 20th 2012, 1:05pm
try to connect the aquaero on different root hub ports on your mainboard.
In the windows eventlog is normaly a long message like this:
Quoted
Application: aquasuite.exe
Description: The process was terminated due to an unhandled exception.
Exception Info: System.ArgumentOutOfRangeException
Stack:
at System.Collections.Generic.List`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].get_Item(Int32)
at Datahandling.DeviceItem.SetDeviceDataClass(DeviceType)
at Datahandling.DeviceItem.set_usb(UsbHid.UsbHidDevice)
at Datahandling.DeviceList.AttachDevice(UsbHid.UsbHidDevice)
we need the long report:
you can send the report text to: info@aqua-computer.de
zdenek
Tuesday, November 20th 2012, 1:31pm
sent
cpachris
Tuesday, November 20th 2012, 4:29pm
mine is still working fine with two AQ5 XT's attached at the same time....even after the upgrade.
zdenek
Tuesday, November 20th 2012, 7:09pm
All betas work ok all the last year.
zdenek
Friday, November 23rd 2012, 11:52am
Any progress? Did you received my email?
Thanks
Zdenek
Friday, November 23rd 2012, 12:05pm
wie fix this with the next update.
zdenek
Friday, November 23rd 2012, 12:25pm
OK. Thanks
