• 09.10.2026, 23:39
pegleg
I have two aquastream xt pumps how would i hook them up together,to use both at the same time.
Saturday, November 17th 2012, 3:06pm
I have two aquastream xt pumps how would i hook them up together,to use both at the same time. thanks
Saturday, November 17th 2012, 9:34pm
each Molex at PSU (no hot plug in/out)
each USB at MB can be separate when u done with configuration (no hot plug in/out)
If u want Aquabus to a AE5 u need a Y-cable to the high Aquabus and must change by one pump the Aquabus Canal over USB (no hot plug in/out)
This post has been edited 2 times, last edit by "EnigmaG" (Nov 18th 2012, 6:38pm)
pegleg
Tuesday, November 20th 2012, 1:07am
thank
pegleg
Thursday, November 29th 2012, 4:02am
can u explain that to me again please,i am waiting for my parts to come in and i think i am going to try two pumps.(aquastream xt) and how would i run the tubing and the pumps.please any one
Thursday, November 29th 2012, 4:37pm
You would just connect both pumps with a aquabus y-adapter to the aquabus highspeed port of the aquaero. Bute before you do this you have to change the aquabus ID of one pump from 10 (default) to 11 via USB with the aquasuite software because otherwise the aquaero is not able to differ between both pumps.
pegleg
Thursday, November 29th 2012, 11:06pm
ok thanks
Thursday, November 29th 2012, 11:37pm
How u want to use the Pumps, serial , parallel or two circle?
pegleg
Friday, November 30th 2012, 12:50pm
well i was thinking serial,but what would be better?
Thursday, December 6th 2012, 9:56pm
As far as I know is it not important where the second Pump is in a serial circle.
I had never the necessity of two Pumps and no experience with it.
pegleg
Tuesday, December 11th 2012, 6:19pm
ok ,thanks..happy holidays
This post has been edited 1 times, last edit by "pegleg" (Dec 11th 2012, 6:20pm)
pegleg
Tuesday, December 25th 2012, 12:46pm
i just want to see how 2 pumps will work lol...well i have another aquastream pump and i got the part i needed to so i can use it now ,so when i hook both of these pumps up i know u have 2 run one pump on channel 10 and the other on 11.now i hook one up to the aquaero 5 on the high speed side then i hook the other pump to the usb on motherboard ? or does both pumps have to be on the aquaero5 high speed? would this be to much pressure for my reservoir or fitting or rad? thanks all merry chrismas and happy new year. :)
