• 17.11.2026, 10:01
mandrix
Dying Power Adjust 2 Ultra?
Saturday, November 24th 2012, 11:40pm
Power Adjust ultra normally runs five fans. Today I also plugged in a High Flow sensor.
First thing I noticed after a while was the fan rpm quit showing up.
Then three of the five fans won't run. It apparently won't ouput enough power to start all five fans.
I can plug the five fan harness into one of the fan outputs on the AQ5 Pro and they all power up just fine.
I've tried resetting the firmware just for grins but apparently it shipped with the latest version.
I've unplugged/plugged the power connection. (with power off)
I've restarted, rebooted and recycled 50 times but no change.
The flow sensor output works fine.
I don't really know what else I can do, can I assume the unit is dead or dying?
Will it not operate with voltage output and a flow sensor simultaneously, and I bricked it somehow?
mandrix
Sunday, November 25th 2012, 1:28am
I'm limping along by swapping some things around. Right now the PA2 is running a single fan and a flow sensor. The rpm and voltage is showing up now but the power % will not.
Actually it seems like it's pretty much stuck on 6.7v running the tiny fan that cools my pump heatsink.
I think it's done for. :(
This post has been edited 1 times, last edit by "mandrix" (Nov 25th 2012, 1:31am)
LarryWill729
Sunday, November 25th 2012, 2:55am
what happens when the high flow sensor is removed from the PA2?
And which High flow sensor are you useing?
AMD FX-8150 OctoCore O.C. 18% to 4.2 GHz on ASUS M5A99X EVO with 16 GB Corsair Dominator W. C. RAM, 2 nVIDIA Geforce 560TI W.C. in SLI, six Western Digital drives for a total of 4.07 TBytes, AquaComputer Aquero 5 Pro, AquaComputer D5 pump, Multiswitch USB, tubemeter and Kyros CPU block. Two coolant loops,CPU & SLI, MB, RAM and AQ5, with two flow meters. Running Windows 7 Professional 64, and using Open Hardware Monitor v0.5.1Beta Aquasuite B16 hardware temps.
cc01
Sunday, November 25th 2012, 3:35am
This ^
If you are using the newer mps type of flow sensor it is designed to be plugged in via USB or the aquabus, not the 3-pin flow header, which is for the older style mechanical flowmeter. Perhaps this is causing problems?
mandrix
Sunday, November 25th 2012, 11:36am
Guys I'm using the older high flow sensor, not the MPS.
Removing it does not change the output of the PA2, ,so I decided to leave it on. However the PA2 seems capable of only producing about 6.7v, and will only run one or two fans.
It seems crippled in terms of power output, as I said it was running 5 fans with no problems before.
Probably merely coincidental that the PA2 started failing when the flow sensor was added, I'm thinking.
This post has been edited 1 times, last edit by "mandrix" (Nov 25th 2012, 11:38am)
mandrix
Monday, November 26th 2012, 12:27pm
Shoggy, what do you think? Is it dying?
If so, will it be replaced?
This post has been edited 1 times, last edit by "mandrix" (Nov 26th 2012, 12:38pm)
Monday, November 26th 2012, 2:21pm
Likely a damaged voltage regulator. Should be send in for a check/repair.
mandrix
Monday, November 26th 2012, 2:53pm
OK. Thanks Shoggy.
mandrix
Wednesday, November 28th 2012, 12:52pm
PA2 on it's way to Germany.
Having to use a motherboard fan header with virtually no control reminds me of why I got the AQ5 in the first place. :) I seriously don't know what Gigabyte was thinking with the lack of fan control on my motherboard.
