• 29.11.2026, 15:58
jpmboy
Aquasuite screenshot 2
Tuesday, November 27th 2012, 1:59am
Grabbing more memory resources over time. (after a brief game session). However, within a few minutes this dropped down to 302K private and 318K working. Learning more... if i turn on data capture for graphing with the built-in function (nice) AS gets more hungry.
Again -the software is working fine, no AS-caused crashes at all.
jpmboy has attached the following image:
AsRock E3Gen3, 2700k @4.6 with cuplex HF, 2 HD7970s with aquaC waterblocks, 16G GSkill 2133, TJ09, ST1500 ps, plextor 256 ssd, 2x1TB WD VRs raid 1, HP 30 inch. Aquacomputer 720XT Mk IV.
Tuesday, November 27th 2012, 7:11am
The memory consumption is ok.
The aquasuite hold every value from each connected device with a history of 60minutes. Each value has a history of 3600 values + times.
The aquaero have ~200 Values.
When you use charts, the charts need also some memory and cpu time to display the graphs. When you use other monitoring software the memory/cpu load is similar to the aquasuite.
cc01
Tuesday, November 27th 2012, 8:57am
If I said that the sky was blue....I'm fairly certain cc01 would jump in and argue with me. I've gotten used to it. :huh:
Here's diplomacy: if it were blue I wouldn't argue. Actually it's cyan for most of the day. Various hues of yellow, red, orange or violet at dusk or dawn, black at night (depending on the light pollution). :)
I'm out of this thread as it seems I can never escape abuse for disagreeing with what doesn't make sense.
jpmboy
Tuesday, November 27th 2012, 5:01pm
Thanks Sanastian. Good software, nice work. The hardware/software package AQ offers is second to none.
Similar threads
