• 11.10.2026, 07:15
hrmes
Incorrect RGB LED color with latest firmwares
Friday, November 30th 2012, 5:35pm
After updating the firmware of AQ5 XT to 1026 and then to 1027 I noticed that the colors of a RGB LED that I have installed in a case fan looked a bit different than before.
After looking at the settings of the LED controller I realized that the current RGB LED values at a given temperature seem to be incorrect.
For example in the attached screenshot at a temperature of 32 C the blue LED value should be less than 20%, yet it is at 31%.
The green LED value should also be less than 80%, but it is at 87%.
Anyone else with incorrect LED colors ?
Edit:
Why not use curves in the LED controller like you can for fans ? Thay way you would have much more control over the color hues.
hrmes has attached the following image:
This post has been edited 1 times, last edit by "hrmes" (Nov 30th 2012, 7:02pm)
Monday, December 3rd 2012, 9:59am
In some way it is correct because internally we use a logarithm which converts your settings to another curve so you get a linear change of brightness to your eyes.
We will have a look if we can adjust the shown values in some way so it is less confusing.
hrmes
Monday, December 3rd 2012, 12:17pm
It seems that the current interpolation method is spline-like. There could be an option in the firmware to use ordinary linear interpolation that would produce a more predictable set of values.
Similar threads
