• 29.09.2026, 20:11
bern43
Aquearo 5 XT Touchscreen not working
Saturday, December 1st 2012, 8:34pm
Only the top two touchscreen buttons on the right on my Aquearo 5 XT seem to be working. Sent a PM to Shoggy and I'm sure we'll figure it out. But has anyone run into this before? Anything I should be setting different or checking? Regretting not getting the Pro version.
hrmes
Saturday, December 1st 2012, 9:27pm
You can try to increase the sensitivity of these keys with the Aquasuite software and see if this helps. Just go to 'User Interface' -> 'Key Settings' and scroll to the bottom where 'Key sensitivities' is and enter higher values for those buttons.
bern43
Sunday, December 2nd 2012, 5:33am
So increasing the values of the buttons that don't work to 30 got them working. The top two that were working to begin with are still at 5. Does this seem right? Why such a difference?
Pilo
Sunday, December 2nd 2012, 6:32am
If it's working now, then it's fine, or not? You can adjust the key sensitivities from 0 to 100 to compensate production tolerances. It's not mandatory that all keys must already work with an sensitivity of 5. 5 is only a preset to avoid unwanted triggering from the start.
Monday, December 3rd 2012, 10:20am
The values differ from system to system so as long as it is working I would not really care about the larger differences between the values.
