• 10.10.2026, 05:04
mrbean
Shoggy: Help needed to purchase MSi Lightning 680 GTX waterblock and twin connect kit
Sunday, January 20th 2013, 12:10pm
Hello Shoggy,
Ok, as I mentioned a while back, I have one GTX 680 Lightning block, and now I got the 2nd card for some SLI action.
I am ready to order the new waterblock from you, but I also need a twin connect adapter, like this one : http://shop.aquacomputer.de/product_info…roducts_id=2495
Will this also work on the MSI 680 Lightning blocks? I will use the Asus Rampage IV Gene motherboard, micro-ATX form factor....
I will appreciate your quick response, then I can order this asap, thanx Shoggy!
Kind regards,
Phillip aka mrbean
This post has been edited 4 times, last edit by "mrbean" (Jan 21st 2013, 10:13pm)
mrbean
Monday, January 21st 2013, 11:07am
Bump.... :)
Jakusonfire
Wednesday, January 23rd 2013, 3:42pm
It says on the 680 Lightning page
The terminal can be replaced with twinConnect kits for SLI configurations (art. no. 23497, 23501 or 23532, not included in delivery)
Which is the type you linked to.
mrbean
Monday, January 28th 2013, 10:24am
Thanx Mate, yeah, I discovered it will work.
Appreciative of your feed back though :)
