• 13.11.2026, 21:51
Mafia
Customise Remote / Display duration / startup timesync
Friday, January 25th 2013, 11:53am
Hello,
I have recently received and installed the Aquaero 5 XT and I am very impressed with it!
I am having a few little issues customising certain parts.
  • Is there any way to customise or change what the buttons do on the remote? Could i set one of the buttons to run a batch file for example? or change channels in Windows Media centre.
  • For my display I have selected 2 screens. Time (which has Permanent ticked) and Software sensor 1-4 temperature (Permanent unticked and duration set to 2 seconds), when I click up or down on the touch screen the Software sensor temperature stays for longer than 2 seconds, in fact it stays for around 30 seconds to 1 minute.
  • I can not find aquacomputerTimeSync.exe in my program file, i guess this has been removed now. So do we have to run Aquasuite 2012 at every boot now?
Thanks in advance
Jerami1981
Sunday, February 17th 2013, 6:16pm
For your display issue I'm guessing when you touch the screen to scroll to another choice the 2 sec duration no longer applies. It shows what you selected and then if nothing is touched it goes back to default after a time which appears to be roughly a minute. If you are wanting your temp sensors to show up on their own my suggestion is this. Set a time duration for the clock which would presumably be a high number and then keep the 2 sec dur for the temp. Ex. I like temps showing most of the time but also like to check in on the clock/flow/and fans. I set the last three to a 3 sec dur each and the temp one to 120 sec. This lets me see the temps most of the time but if i watch for 2 minutes i can get a quick glance at the other stuff. Another option is to make a couple of windows in Overview to be displayed on your desktop at all times. My pc recently moved to far from me to see the screen and i have found the screen displays invaluable.
Wednesday, February 20th 2013, 7:42am
This is replaced by aqua comuter service. When the service is running your device will be automatically synchronized.
In the youer interface page is a time: "Display duration after page selection"
