• 29.09.2026, 11:38
Phatboy69
XML data export
Thursday, February 28th 2013, 4:24pm
Hi Shoggy and crew!
I have a request..
Is there a way to get clean XML out of the reporting engine? The XMLNS attributes arent understood by a few programs like LCDhost that need clean XML.
I can get aquasuite 2012 XML data to work fine if it is clean, but aquasuite puts the attributes in so the plugin cant parse them.
example code that currently doesnt work because of the xmlns attributes.
<?xml version="1.0" encoding="utf-8"?>
<LogDataExport xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<name>
CPU
</name>
<exportTime>
2013-03-01T00:42:01.418533+11:00
</exportTime>
<logdata>
<LogDataSet>
<t>
2013-03-01T00:42:01.044
</t>
<value>
34.09
</value>
<name>
CPU Water out T2
</name>
<unit>
°C
</unit>
<valueType>
temperature
</valueType>
<device>
aquaero 5 (A5)
</device>
</LogDataSet>
</logdata>
</LogDataExport>
Same XML that does work because the XMLNS attributes are removed.. (manually)
<LogDataExport>
<name>
CPU
</name>
<exportTime>
</exportTime>
<logdata>
<LogDataSet>
<t>
</t>
<value>
34.09
</value>
<name>
CPU Water out T2
</name>
<unit>
°C
</unit>
<valueType>
temperature
</valueType>
<device>
aquaero 5 (A5)
</device>
</LogDataSet>
</logdata>
</LogDataExport>
End result!
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
Phatboy69
Wednesday, March 6th 2013, 3:17pm
LCDHost for G19 colour screen..
I got some scripting done to clean the xml with an "xslt" xml template to remove the xml attributes and make a clean xml file. A batch file runs every 5 secs against the aquasuite xml file to strip the stuff that LCDHost doesnt like.
The problem I have now is that the Dataviewer looks like it can only handle 1 instance so I cant have seperate xml files processed by seperate dataviewers. While I can set each dataviewer to its own data source the data txt and data bar instances will only read data from the last Dataviewer in the list. It looks like the dataviewer templates cannot be matched to a particular connector?!?!? Ive tried making a parsing map file and having all the data in the same XML file but i dont know enough to make it work or even if the current xml structure from aquasuite 2012 would work.
Anyone got any advice?
Batch file
Source code
1
2
3
4
5
:top
C:\libxslt-1.1.26.win32\bin\xsltproc.exe -o c:\cpu-clean.xml c:\CPU.xsl c:\CPU.xml
C:\libxslt-1.1.26.win32\bin\xsltproc.exe -o c:\gpu-clean.xml c:\CPU.xsl c:\GPU.xml
timeout 5
goto top
Before cleaning
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
  <name>CPU</name>
  <exportTime>2013-03-07T01:03:58.0461184+11:00</exportTime>
  <logdata>
    <LogDataSet>
      <t>2013-03-07T01:03:57.912</t>
      <value>35.41</value>
      <name>CPU Water out T2</name>
      <unit>°C</unit>
      <valueType>temperature</valueType>
      <device>aquaero 5 (A5)</device>
    </LogDataSet>
  </logdata>
</LogDataExport>
After cleaning
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
<LogDataExport>
  <name>CPU</name>
  <logdata>
    <LogDataSet>
      <unit>°C</unit>
    </LogDataSet>
  </logdata>
</LogDataExport>
Result in LCDHost
Here's a combined XML from aquasuite that I cant seem to create a map file for.
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
<LogDataExport>
  <name>Temps</name>
  <exportTime>2012-11-14T14:13:32.2662968+11:00</exportTime>
  <logdata>
    <LogDataSet>
      <t>2012-11-14T14:13:32.058</t>
      <value>31.84</value>
      <name>CPU Water In Temp</name>
      <unit>°C</unit>
      <device>aquaero 5</device>
    </LogDataSet>
    <LogDataSet>
      <value>28.28</value>
      <name>GPU Water In Temp</name>
      <unit>°C</unit>
    </LogDataSet>
  </logdata>
</LogDataExport>
Phatboy69
Thursday, March 7th 2013, 3:31pm
Great News!!! I got it all working!!!!!!!!!!!!!!
Im using 2 data connectors in LCDHost to pickup the CPU and GPU water loop temps.. I can now add anything I like from Aquasuite 2012 XML logs to the G19 screen!
I had to create a seperate map file for each dataconnector and use the cleaned XML files which I cleaned with the XSL template script. (now running every 10secs as water temps dont change that quickly.)
OCCT Powersupply test running in background.
This shows the CPU Water Temp Data Template below.
{logdata.LogDataSets.CpuName} {logdata.LogDataSets.CpuTemp}°C
This shows the Data Connector XML file and XML Map file.
The XML export from Aquasuite 2012.
CPU datamap file that tells LCDHost how to read the cleaned XML file from Aquasuite after its been cleaned with my XSL batchfile. It took hours and hours of trial and error to get this to work!
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
[Format]
type=xml		; xml / txt / ini
dataExpiry=0		; # of seconds to consider the data invalid
language=EN		; The language used by the lists in this file. Other languages can be added by copying the lists to a new text file,
			; translating them and then saving the file as "lists.<language>.txt", e.g. lists.RU.txt
[Parsing]
logdata.LogDataSets
logdata.LogDataSets.CpuTime
logdata.LogDataSets.CpuTime.*Value	logdata.LogDataSet.t
logdata.LogDataSets.CpuTime.Level	logdata.LogDataSet.t
logdata.LogDataSets.CpuTime.Level.Code	logdata.LogDataSet.t
logdata.LogDataSets
logdata.LogDataSets.CpuTemp.*Value	logdata.LogDataSet.value
logdata.LogDataSets.CpuTemp.Level	logdata.LogDataSet.value
logdata.LogDataSets.CpuTemp.Level.Code	logdata.LogDataSet.value
logdata.LogDataSets
logdata.LogDataSets.CpuName.*Value	logdata.LogDataSet.name
logdata.LogDataSets.CpuName.Level	logdata.LogDataSet.name
logdata.LogDataSets.CpuName.Level.Code	logdata.LogDataSet.name
logdata.LogDataSets
logdata.LogDataSets.CpuUnit
logdata.LogDataSets.CpuUnit.*Value	logdata.LogDataSet.unit
logdata.LogDataSets.CpuUnit.Level	logdata.LogDataSet.unit
logdata.LogDataSets.CpuUnit.Level.Code	logdata.LogDataSet.unit
logdata.LogDataSets
logdata.LogDataSets.CpuvalueType
logdata.LogDataSets.CpuvalueType.*Value	logdata.LogDataSet.valueType
logdata.LogDataSets.CpuvalueType.Level	logdata.LogDataSet.valueType
logdata.LogDataSets.CpuValueType.Level.Code	logdata.LogDataSet.valueType
logdata.LogDataSets
logdata.LogDataSets.CpuDevice
logdata.LogDataSets.CpuDevice.*Value	logdata.LogDataSet.device
logdata.LogDataSets.CpuDevice.Level	logdata.LogDataSet.device
logdata.LogDataSets.CpuDevice.Level.Code	logdata.LogDataSet.device
The GPU Datamap file.
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
[Format]
[Parsing]
logdata.LogDataSets
logdata.LogDataSets.GpuTime
logdata.LogDataSets.GpuTime.*Value	logdata.LogDataSet.t
logdata.LogDataSets.GpuTime.Level	logdata.LogDataSet.t
logdata.LogDataSets.GpuTime.Level.Code	logdata.LogDataSet.t
logdata.LogDataSets
logdata.LogDataSets.GpuTemp
logdata.LogDataSets.GpuTemp.*Value	logdata.LogDataSet.value
logdata.LogDataSets.GpuTemp.Level	logdata.LogDataSet.value
logdata.LogDataSets.GpuTemp.Level.Code	logdata.LogDataSet.value
logdata.LogDataSets
logdata.LogDataSets.GpuName
logdata.LogDataSets.GpuName.*Value	logdata.LogDataSet.name
logdata.LogDataSets.GpuName.Level	logdata.LogDataSet.name
logdata.LogDataSets.GpuName.Level.Code	logdata.LogDataSet.name
logdata.LogDataSets
logdata.LogDataSets.GpuUnit
logdata.LogDataSets.GpuUnit.*Value	logdata.LogDataSet.unit
logdata.LogDataSets.GpuUnit.Level	logdata.LogDataSet.unit
logdata.LogDataSets.GpuUnit.Level.Code	logdata.LogDataSet.unit
logdata.LogDataSets
logdata.LogDataSets.GpuvalueType
logdata.LogDataSets.GpuvalueType.*Value	logdata.LogDataSet.valueType
logdata.LogDataSets.GpuvalueType.Level	logdata.LogDataSet.valueType
logdata.LogDataSets.GpuValueType.Level.Code	logdata.LogDataSet.valueType
logdata.LogDataSets
logdata.LogDataSets.GpuDevice
logdata.LogDataSets.GpuDevice.*Value	logdata.LogDataSet.device
logdata.LogDataSets.GpuDevice.Level	logdata.LogDataSet.device
logdata.LogDataSets.GpuDevice.Level.Code	logdata.LogDataSet.device
The batch file that runs the XSL template against the raw XML files from Aquasuite.
Source code
1
2
3
4
5
:top
timeout 10
goto top
Here's the all important XSL template named cpu.xsl that cleans the XML file of all the stuff that LCDHost doesnt like! Took me a while to work this one out!
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
<xsl:stylesheet
  xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
  version="1.0">
 <xsl:output method="xml" version="1.0" indent="no" omit-xml-declaration="yes"/>
  <xsl:template match="*">
    <xsl:element name="{local-name()}">
      <xsl:apply-templates select="@* | node()"/>
    </xsl:element>
  </xsl:template>
  <xsl:template match="@*">
    <xsl:attribute name="{local-name()}">
      <xsl:value-of select="."/>
    </xsl:attribute>
  </xsl:template>
  <xsl:template match="text() | comment() | processing-instruction()">
    <xsl:copy/>
  </xsl:template>
</xsl:stylesheet>
Heres the cleaned XML for the CPU Water Temp that LCDHost uses.. (the GPU looks the same)
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
<LogDataExport>
  <name>CPU</name>
  <exportTime>2013-03-08T01:24:18.4380893+11:00</exportTime>
  <logdata>
    <LogDataSet>
      <t>2013-03-08T01:24:17.577</t>
      <value>34.9</value>
      <name>CPU Water in T1</name>
      <unit>°C</unit>
    </LogDataSet>
  </logdata>
</LogDataExport>
Namron
Thursday, March 7th 2013, 4:36pm
HOLY Way over my head Batman!!!!!... But Fantastic work Phatboy, Can see you must have spent a long long time getting this sorted & So very very impressed & Pleased for you... Congrats & Well Done Dude :thumbsup:
N.
Phatboy69
Saturday, March 23rd 2013, 11:56am
The new 2013-1 versions of Aquasuite xml export all works properly now!
I managed to get the fan rpm signals displayed on the G19 too. The next big challenge is to setup a dedicated Aquasuite monitoring page for the G19.
novax1
Saturday, March 30th 2013, 9:29am
Hello
First I want to say that if my explanation. not very clear. Spanish I have to translate English.
Mine is a Aquastream xt and want to continue their work. I also use Lcdhost.
in my G19.
the problem is not where to put the codes that you have written.
and copied CPU.datamap ok i created. The GPU not used it.
which donot like the other codes. use
1-The batch file runs the XSL template That against the raw XML files from AquaSuite.
2-Here's the all important XSL template named cpu.xsl That cleans the XML file of all the stuff that does LCDHost like! Took me a while to work this one out!
Heres the cleaned XML for the CPU Water Temp That LCDHost use .. (the GPU looks the same)
displayed data are not updated
I put some pictures of it and succeeded.
novax1 has attached the following image:
This post has been edited 2 times, last edit by "novax1" (Mar 30th 2013, 9:42am)
Phatboy69
Sunday, March 31st 2013, 4:45am
Your very close! You need to make a batch file (which I called xml.bat) and put this code in it and set it to run at startup as a system scheduled task with task scheduler. Change the timeout value to how often you want the data to update.
Source code
1
2
3
4
5
:top
timeout 1
goto top
This post has been edited 1 times, last edit by "Phatboy69" (Mar 31st 2013, 4:47am)
novax1
Sunday, March 31st 2013, 5:37am
Hello
and created the file and xml.bat.
but not how to set it in the task scheduler. Windows 8
I can help
this code as I have to put cleaning.
<xsl: stylesheet
xmlns: xsl = "http://www.w3.org/1999/XSL/Transform"
version = "1.0">
method="xml" <xsl:output version="1.0" indent="no" omit-xml-declaration="yes"/>
</ xsl: element>
</ xsl: template>
</ xsl: attribute>
</ xsl: template>
<xsl:copy/>
</ xsl: template>
</ xsl: stylesheet>
Sorry but I have no experience in xml
thanks
This post has been edited 1 times, last edit by "novax1" (Mar 31st 2013, 5:45am)
Phatboy69
Sunday, March 31st 2013, 11:50am
Hello
I can help
<xsl: stylesheet
version = "1.0">
</ xsl: element>
</ xsl: template>
</ xsl: attribute>
</ xsl: template>
<xsl:copy/>
</ xsl: template>
</ xsl: stylesheet>
thanks
Im very sorry but Im not understanding your english translation. Can you post in spanish and Ill try translate for myself.
Phatboy69
Sunday, March 31st 2013, 11:51am
Here's my new G19 Screens for Aquasuite 2013.
I have added Aquasuite alarms to the G19 screen and critical dials & indicators on a dedicated Aquasuite screen.
Main G19 Page screenshot with all ok, and screenshot with 1 pump turned off to simulate a failure.
Aquasuite G19 Page screenshot with all ok, and screenshot with 1 pump turned off to simulate a failure.
A Screen shot of some of the LCDHost settings for the Aquasuite page.
This post has been edited 1 times, last edit by "Phatboy69" (Mar 31st 2013, 12:03pm)
novax1
Sunday, March 31st 2013, 12:12pm
Hello
I can help
<xsl: stylesheet
version = "1.0">
</ xsl: element>
</ xsl: template>
</ xsl: attribute>
</ xsl: template>
<xsl:copy/>
</ xsl: template>
</ xsl: stylesheet>
thanks
Saludos
no se como poner el archivo creado xml.bat en el programador de tareas.
El código de limpieza que le indico como tengo que usarlo y donde lo tengo que poner.
This post has been edited 1 times, last edit by "novax1" (Mar 31st 2013, 12:14pm)
Phatboy69
Sunday, March 31st 2013, 12:15pm
Under full load with OCCT powersupply test.
Pic of my power meters showing power drawn at wall from each PSU. Ouch!
novax1
Sunday, March 31st 2013, 12:16pm
impressive :thumbsup: :thumbsup:
novax1
Sunday, March 31st 2013, 12:24pm
saludos
el archivo que e creado xml.bat no se como ponerlo en el programador de tareas.
el código de limpieza que le indico no se donde usarlo. y como ponerlo. :?: :wacko:
Gracias por la ayuda
Phatboy69
Sunday, March 31st 2013, 12:48pm
Saludos
[/quote]1.0
1. First run task scheduler (just type task scheduler on the windows 8 start screen and press enter and it should start)
2. Create a new task (right click "new task")
3. Change it to a system run task (click "change user or group" and type "System" under the object name and press enter)
4. Check the "Hidden" check box
5. Give the task a name such as XML batch
6. Set a New Trigger as "At System Startup" and make sure the enable check box is ticked (click the "trigger" tab and click "new" then choose the "at system startup" drop box
7. Set the action to start the xml.bat file (click "actions" tab and "new" button then choose "start a program" and browse to where the batch file is saved
8. Finally click on the "OK" button to save and finish.
9. You can now right click it to run it manually. Next time your system starts it should start automatically.
For the XSL file which cleans the Aquasuite files you do not need to change anything.
Just copy the code from the XSL code window above to a new txt file and save it as CPU.XSL.
It parses the Aquasuite XML files to make them compatible with LCDHost.
You need to download the libxslt-1.1.26.win32 package which is an XSL processor and save it to your C drive.
Save all the XML and XSL files to the same directory. In my case I saved them all to the C drive in the root folder and the XSL processor to the directory you can see above.
You also need to update the xml.bat file with whatever XML files you want cleaned and name the new files "cleaned" like I did to make it easy to see which one to use.
You need to update any paths in the bat file to match where your files are and keep the xml.bat in the same directory as all your other files.
If you cant do this from these instructions then perhaps someone else may help. Unfortunately you may not have the skills to do it as it's not for a novice!
novax1
Sunday, March 31st 2013, 7:26pm
Thank you for your help.
but I have problems with libxslt-1.1.26.win32. in windows 8
dll missing many. . when running xml.bat.
still here trying not to get anything. :evil: :evil: :wacko: :wacko:
Gracias por su ayuda.
pero tengo problemas con libxslt-1.1.26.win32 .en windows 8
faltan muchos dll. . cuando se ejecuta xml.bat.
todavia aqui intentando no consigo nada
novax1
Sunday, March 31st 2013, 7:54pm
can not get the code to work cleaning :wacko:
This post has been edited 2 times, last edit by "novax1" (Mar 31st 2013, 11:28pm)
novax1
Monday, April 1st 2013, 9:50am
este es el error que muestra cuando ejecuto XML.bat.
This is the error that shows when I run XML.bat.
Phatboy69
Monday, April 1st 2013, 11:18am
You can try this dll dependency tool to see what dll is missing. There maybe another System DLL in the chain of dependencies that is missing. Sorry I cant help you more than that at this stage. I have windows 8 installed on my work laptop so might be able to recreate the problem later this week for you but I wouldnt count on it. http://www.dependencywalker.com/
novax1
Thursday, April 4th 2013, 12:58pm
Hola
Le doy las gracias por su ayuda.
Creo haber solucionado el problema con el editor libxslt-1.1.26.win32
Pero sigo sin poder mostrar los datos le pongo unas imágenes.
Los programas en ejecución, aquasuite, Lchost, bat
In tetare explicarle donde tengo los archivos de los datos de
aquasuite 2013-2.
Los XML creados, el xml.bat, CPU.xsl. Le pongo unas imágenes
Ingles traducido.
Hello
I thank you for your help.
I have solved the problem with the publisher libxslt-1.1.26.win32
But I still can display the data I put some pictures.
Running programs, AquaSuite, Lchost, bat
In tetare explain where I have the data files AquaSuite 2013-2.
The XML created, the xml.bat, CPU.xsl. I put some pictures
This is the file and were able to repair.libxslt-1.1.26.win32
if you want to look
http://www.mediafire.com/?0i9d8nj2ek847cn
novax1 has attached the following images:
This post has been edited 3 times, last edit by "novax1" (Apr 4th 2013, 2:09pm)
