• 05.10.2026, 06:35
Phatboy69
XML Export Error/Bug Aquasuite 2012-6
Thursday, March 14th 2013, 8:23am
After setting up XML data export I get the following error when I reboot and Aquasuite restarts. Currently the only way to fix this is to reinstall Aquasuite and delete existing settings when prompted.
If I dont setup XML export, I can stop and restart Aquasuite fine.
1st Application Error
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
Log Name:      Application
Source:        .NET Runtime
Date:          14/03/2013 6:14:39 PM
Event ID:      1026
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      Hilton-PC
Description:
Application: aquasuite.exe
Framework Version: v4.0.30319
Event ID:      1026
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      Hilton-PC
Description:
Description: The process was terminated due to an unhandled exception.
Exception Info: Microsoft.CSharp.RuntimeBinder.RuntimeBinderException
Stack:
   at DynamicClass.CallSite.Target(System.Runtime.CompilerServices.Closure, System.Runtime.CompilerServices.CallSite, System.Object)
   at System.Dynamic.UpdateDelegates.UpdateAndExecute1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.Double, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.Runtime.CompilerServices.CallSite, System.__Canon)
   at AquaComputer.Logdata.LoggingProcess+LoggingJob.AddLogDataFile()
   at AquaComputer.Logdata.LoggingProcess+LoggingJob.AddLogData()
   at AquaComputer.Logdata.LoggingProcess.DoLoggingJobs()
   at AquaComputer.Logdata.LoggingProcess.workerThreadMethod(System.Object)
   at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
   at System.Threading.ThreadHelper.ThreadStart(System.Object)
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name=".NET Runtime" />
    <EventID Qualifiers="0">1026</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2013-03-14T07:14:39.000000000Z" />
    <EventRecordID>101294</EventRecordID>
    <Channel>Application</Channel>
    <Computer>Hilton-PC</Computer>
    <Security />
  </System>
  <EventData>
    <Data>Application: aquasuite.exe
Stack:
</Data>
  </EventData>
</Event>
Followed by this error
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
  <Provider Name="Application Error" />
  <EventID Qualifiers="0">1000</EventID>
  <Level>2</Level>
  <Task>100</Task>
  <TimeCreated SystemTime="2013-03-14T07:14:40.000000000Z" />
  <EventRecordID>101295</EventRecordID>
  <Security />
  </System>
- <EventData>
  <Data>aquasuite.exe</Data>
  <Data>1.0.0.15</Data>
  <Data>50d196c6</Data>
  <Data>KERNELBASE.dll</Data>
  <Data>6.1.7601.18015</Data>
  <Data>50b8479b</Data>
  <Data>e0434352</Data>
  <Data>0000000000009e5d</Data>
  <Data>11d4</Data>
  <Data>01ce208396989bad</Data>
  <Data>C:\Program Files\aquasuite 2012\aquasuite.exe</Data>
  <Data>C:\Windows\system32\KERNELBASE.dll</Data>
  <Data>d5f00646-8c76-11e2-9828-0026833a26bf</Data>
  </EventData>
  </Event>
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
Thursday, March 14th 2013, 11:02am
Thank you, the bug is fixed in the next version.
The next version will be released end of the month.
jpmboy
Thursday, March 14th 2013, 6:31pm
Excellent! :thumbup:
AsRock E3Gen3, 2700k @4.6 with cuplex HF, 2 HD7970s with aquaC waterblocks, 16G GSkill 2133, TJ09, ST1500 ps, plextor 256 ssd, 2x1TB WD VRs raid 1, HP 30 inch. Aquacomputer 720XT Mk IV.
Phatboy69
Tuesday, March 19th 2013, 8:14am
FYI a clean win 7 64bit install with full .net 4 client and C++ updates has fixed this crash. Not sure what it was.
I still however get an immediate crash when I try and add a fan sensor value to xml export.
