• 14.11.2026, 16:39
slavearm
MPS 400 died?
Friday, March 29th 2013, 9:37pm
Temp sensor works, I can connect and calibrate from USB etc, but cannot get the "Current unscaled value" to be anything but 0. Was working for a couple of months now.
_KaszpiR_
Monday, April 1st 2013, 3:42pm
MPS has pressure difference sensor, make sure you have not selected auto calibration, especially with running flow, because the device will think that the current pressure means zero.
slavearm
Thursday, April 4th 2013, 7:04am
Yah, I tried to recalibrate. Turned pumps off and re-zeroed. Nothing still.
_KaszpiR_
Friday, April 5th 2013, 10:23pm
Did you update the AquaSuite?
I just checked and mine MPS 200 shows unscaled value 4.....
Edit:
Make sure to be able to have an ability to move the MPS, looks like if the air bubbles get into that tiny pressure measuring holes, the whole device gets wrong readings.
I just stirred mine a bit and it started to display proper values.
But more important thing, why it did not trigger the alarms (maybe beacause I use USB only connection?)
Edit2:
looks like my sensor went insane and I cannot get any sensible infor from it, will have to dismantle it from the setup tomorrow and check it . :(
This post has been edited 5 times, last edit by "_KaszpiR_" (Apr 6th 2013, 12:34am)
slavearm
Tuesday, April 9th 2013, 6:44am
Looks like RMA time. I cannot get this thing to show up as really anything now. I worked fine for months. Its a major PITA to get out since it is sitting in a very inconvienient spot to remove and not drench the rest of my computer.
_KaszpiR_
Wednesday, April 10th 2013, 3:47pm
I have connected my MPS to the Aquacomputer via aquabus and left it overnight.
Here is the result.
Strangely it 'works' sometimes or something like that.
I wanted to remove and clean the device last weekend but had some extr work. But the next weekend I'll see what's in there.
Mayeb this is caused by some gunk from the liquid?
_KaszpiR_
Friday, July 19th 2013, 12:00am
Unfortynately the device is making issues again :(
Similar threads
