• 29.11.2026, 16:32
cpachris
Gauge Chart for Flow Sensor Reading
Tuesday, April 2nd 2013, 8:42pm
Has anyone successfully used a gauge chart for a reading from a flow sensor? When I put the chart on the page, the value that the needle shows in the gauge is inaccurate. The statistic data in the gauge chart shows the proper value...but the gauge chart needle shows a very high number. For example, I have a flow sensor plugged into a PA2, and the aquasuite correctly shows the sensor value as 0.7 gpm. When I add a gauge chart to a page and choose that flow sensor as the data source....the gauge needle goes to about 125. The statistic data in the chart still correctly shows the value of 0.7 gpm....but the needle in the gauge goes to 125. Not sure if its trying to display it in a different conversion (lph, or something like that) or what it might be doing.
Would appreciate it if someone else could try, since it will only take a few minutes and won't mess up anything you may have set up already. Thanks in advance.
mandrix
Wednesday, April 3rd 2013, 10:25am
Sounds like lph, chris. Look under User Interface as well as Aquasuite settings and make sure both are set the same as you want to display.
cpachris
Wednesday, April 3rd 2013, 3:52pm
Both of those sections within Aquasuite (user interface and Aquasuite settings) have gallons per minute chosen. Can you put together a quick page with a chart and see if you have the same issue?
Jakusonfire
Wednesday, April 3rd 2013, 4:54pm
I gave up on trying to use gauges for flow because it would always read the maximum possible for the gauge. I have everything set to LPM but the guages always shoot to max, even if its in the hundreds
mandrix
Wednesday, April 3rd 2013, 4:56pm
Hmm. On the gauge, the needle sits maxed all the way to the right. To be honest, I never put any time into figuring the gauge out.
Hopefully someone else knows how to set it up.
Jakusonfire
Wednesday, April 3rd 2013, 5:12pm
Its the same thing with using bar graphs for flow too, always shown 100%
mandrix
Wednesday, April 3rd 2013, 6:04pm
Yeah, I noticed that.
Strangely enough, the gauge chart is the one I would want to use with flow. :rolleyes:
The usefulness of the gauges escapes me, but l really haven't sunk any time into it. Lately I'm happy if I can change something without AS crashing on me.
The software seems to get confused when there are two AQ5's in use.
cpachris
Wednesday, April 3rd 2013, 6:25pm
Thanks for checking. Maybe Aquacomputer will take a look at the issue and fix it. I'd like to be able to use the gauge chart for my flow meter sensors.
and yes....I'm getting a lot of software issues with Aquasuite 2013-2. Pretty steady if I'm not making changes....just looking at pages. But if I start tweaking controllers or anything...it craps out a lot. Usually have to reboot the machine to get it back running correctly.
mandrix
Wednesday, April 3rd 2013, 6:59pm
Same here.
Namron
Wednesday, April 3rd 2013, 9:27pm
That's a strange one chaps!!.... I just done a couple of gauge charts for my two flow sensors on a page & mine are reading the correct readings with the needle... I'm using L/ph by the way..
I have to pop out now, but i'll give the G/ph a shot when I get back, just in case it's something to do with the gallons readings that is screwing the suite up??..
N.
Edit*... Yup!!!.. same here.. As soon as I change from L/ph to G/ph the needle goes way above what it should be reading. I've played around with various decimal settings & gauge numbering layouts but can't get it to read correct gallons as per the sensor. I can't think what else to try as I've messed around with many settings too see if I could get the needle reading something close to what it should..
All seems OK with the L/ph e.t.c settings It's just when you go over to Gallons it seems to screw up??..
Like you say..hopefully AC can have a look at this & either tell us what were doing wrong or find & sort the G/ph needle readings problem :D .. I'll go back to my L/ph for now though thanks ;) ...
N.
This post has been edited 1 times, last edit by "Namron" (Apr 3rd 2013, 10:20pm)
Jakusonfire
Thursday, April 4th 2013, 1:36am
Litres per minute does not work correctly either
Namron
Thursday, April 4th 2013, 1:39am
Very odd..... The litres one works fine with me ?(
Jakusonfire
Thursday, April 4th 2013, 1:43am
Per minute or per hour though?
Edit;
This post has been edited 2 times, last edit by "Jakusonfire" (Apr 4th 2013, 4:19am)
Namron
Thursday, April 4th 2013, 1:49am
ahhh... per hour.... Sorry Jak I missed your per minute reference :whistling:
I'll give it another shot later today when I get a moment & see what I get when it's per minute....
This post has been edited 4 times, last edit by "Namron" (Apr 4th 2013, 1:54am)
mandrix
Thursday, April 4th 2013, 1:09pm
The only way I can get the gauge to work with flow correctly is lph.
I have managed to lockup AS2013 10 times, though. :rolleyes:
This post has been edited 1 times, last edit by "mandrix" (Apr 4th 2013, 1:10pm)
Thursday, April 4th 2013, 1:24pm
in the next version the problems with the gauge fixed.
mandrix
Thursday, April 4th 2013, 2:27pm
Great. Thanks, Sebastian.
cpachris
Thursday, April 4th 2013, 10:30pm
much appreciated.
Not sure if you are seeing the same thing Sebastian, but I get a ton of lock-ups where I have to reboot the computer to get Aquasuite responsive again, if I'm making changes in controllers. I have both an XT and LT.
mandrix
Friday, April 5th 2013, 12:51am
Something changed between AS2013 and AS2013-2. I had some problems with the first version, but much more with v2. Just out of the blue it seems to "lose" one of the Aquaero's and I have to reboot to fix it. This is usually after changing calibrations, controllers, etc.
