• 12.11.2026, 13:27
novax1
Thursday, April 4th 2013, 5:47pm
ya consigo mostrar información actualizada .
falta definir External sensor , Fan . Flow.
como debo poner .
and get show updates.
missing for External Sensor, Fan. Flow.
as I put
{logdata.LogDataSets.CpuName} {logdata.LogDataSets.CpuTemp}°C.
gracias.
This post has been edited 1 times, last edit by "novax1" (Apr 4th 2013, 5:48pm)
novax1
Thursday, April 4th 2013, 6:34pm
and to show temperatura.agua information.
sampling and temperature information. external sensor
but the fan out many numbers?.
didnot like show flow.
regards
novax1 has attached the following image:
Phatboy69
Thursday, April 4th 2013, 11:32pm
regards
If you put this :%.2f at the end of the fanrpm data template inside the brackets it will set it to 2 decimal places. (change 2 to zero to have no decimal places)
{logdata.LogDataSets.Fanrpm:%.2f}
If you want to show flow as GPM instead of the default Liters per hour use this formula to convert it.
{={logdata.LogDataSets.GPUFlowGPM}/227.124708:%.2f}
Nice job in getting it to work. I look forward to seeing what screen layout you come up with.
This post has been edited 2 times, last edit by "Phatboy69" (Apr 4th 2013, 11:41pm)
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
novax1
Friday, April 5th 2013, 12:36am
Thanks - Phatboy69
and this is what I got so far.
morning. will put. one. design. of time with this.
Greetings friend
This post has been edited 1 times, last edit by "novax1" (Apr 5th 2013, 12:37am)
novax1
Friday, April 5th 2013, 11:37am
hello
for now I am. creating more.
this is in two phases. :thumbup:
1 - presentation.
2 - visualization. data. Aquastream. xt.
novax1 has attached the following images:
This post has been edited 1 times, last edit by "novax1" (Apr 5th 2013, 11:45am)
Phatboy69
Friday, April 5th 2013, 11:39am
Looking good! Maybe change the scale for temperatures to read maximum at 50c
novax1
Friday, April 5th 2013, 11:48am
is right. realized I had not.
Thank you.
This shows you the alert as a fact.
and this modified
regards :thumbsup:
This post has been edited 1 times, last edit by "novax1" (Apr 5th 2013, 11:53am)
Phatboy69
Friday, April 5th 2013, 12:04pm
Are you using a background pic for the gauges or gradient fill? How did you get the tick marks to be white?
novax1
Friday, April 5th 2013, 12:16pm
used for background images. changed with photoshop.
Here they are for you
http://www.mediafire.com/?6dcr4r3rlql7j1r
novax1
Saturday, April 6th 2013, 11:26am
Hello
Phatboy69, as I can put an alert,
with 1 pump turned off to simulate a failure
regards
Phatboy69
Sunday, April 7th 2013, 11:58am
You need to setup alarms in Aquasuite and export the alarm status to an xml file. Clean with the batch script and then setup LCDHost as follows.
Connector just like the others
Setup the indicator
Setup any text warning with conditional formulas so it doesnt appear unless the alarm is triggered.
Heres the sample cleaned xml file.
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
<LogDataExport>
<name>
Alarm
</name>
<exportTime>
2013-04-07T19:57:59.5025728+10:00
</exportTime>
<logdata>
<LogDataSet>
<t>
2013-04-07T19:57:59.260
</t>
<value>
0
</value>
<name>
Actual alarm level
</name>
<unit/>
<valueType>
number
</valueType>
<device>
aquaero 5
</device>
</LogDataSet>
</logdata>
</LogDataExport>
Phatboy69
Sunday, April 7th 2013, 4:17pm
New Work in progress.. Im making a new Overview / Status page and I finally worked out how to make imagemap files for images! So I can set icons for status of water/fan/pump status!
novax1
Sunday, April 7th 2013, 4:47pm
no. how to set the alarm on AquaSuite :?:
Phatboy69
Monday, April 8th 2013, 11:26am
Set alarms with temperature, flow or pump rpm alerts. Set a warning and alarm.
I have mine set to give warning if maximum temp is reached and if temp keeps rising it shuts down.
I also set warning and apply full power for low flow rate.
Then set actions for the alarm level.
novax1
Monday, April 8th 2013, 1:17pm
Thank you very much for your help.
but Aquastream xt. no way to configure. :( :(
a great job.
this is the picture
novax1
Tuesday, April 9th 2013, 9:18pm
hello
you changed. Status Icons / Silk 14x14/imagemap.txt? :?:
can set an example. please ?(
thanks
Phatboy69
Wednesday, April 10th 2013, 7:00am
hello
thanks
The imagemap uses the short codes here to choose which image to render.
In the datamap file I have added a 3 column lookup table (list) which tells the imagemap which sensor value to lookup the shortcode for.
[List:TempStatuses] is the lookup table where each tab delimited entry is;
column 0, numeric value of the sensor which determines which short code (column 1) and caption (column 2) to apply.
If temp is lower than 15 then NA is given, if temp is higher than 15 but below 20 then LO or LOW are given.
list:TempStatuses,2 is another tab delimited sensor lookup which uses the list lookup value for column 2 (Caption) which in this case above would be LOW
list:TempStatuses,1 is the same but uses column 1 (Short Code). This is the code that the image map is using to determine which image to render in the imagemap.
In the example above if my CPU water temp is at 18c then the datamap presents the shortcode LO to the imagemap, which then says to render image 2_good_low.png from the 14x14 silk icon set.
Once you have the layout loaded with your icon set in the sub directory (using G19-eos as an example) you put a dataviewerimage on the layout and tell it which image map to use.
(in my case im using the default one from the eos layout in the silk icon folder)
And you also use the datamap sensor lookup to tell it what value to use in the lookup.
In my case the dataviewerimage lookup {logdata.LogDataSets.CpuTemp.Level.Code} returns the shortcode for the CPU water temp from the datamap file which then tells the imagemap to render the image 2_good_low.png
The lookup tables (lists) in the datamap can be used to render dynamic images for dataviewerimage in your layout, or dynamic text from the Caption column in the list in the dataviewertext widget.
This is the default imagemap file for the eos layout which im using.
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
; The image map file instructs the SpeedFan Status Image on what image
; file should be displayed for what circumstance. The images listed
; need to be in the same folder.
; The format is as follows:
; <Code>	<Image File>
; Note that each item is seperated by a tab.
; You can miss out any of the codes below and the Status Image will
; try to adapt sensibly. Usually this results in removing a threshold,
; apart from in the case ok leaving out the OK code, in which case no
; icon will be displayed whilst within the desired range.
NA	0_NA.png	; Icon for when data is unavailable
VLO	1_low.png	; Icon for when Value < Very Low
LO	2_good_low.png	; Icon for when Value < Low
OK	3_good.png	; Icon for when Low <= Value < High
HI	4_warning.png	; Icon for when Value >= High
VHI	5_danger.png	; Icon for when Value >= Very Low
This is my Aquasuite CPU water temp datamap.
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
[Format]
type=xml		; xml / txt / ini
dataExpiry=0		; # of seconds to consider the data invalid
language=EN		; The language used by the lists in this file. Other languages can be added by copying the lists to a new text file,
			; translating them and then saving the file as "lists.<language>.txt", e.g. lists.RU.txt
[List:TempStatuses]
; lower bound	Short Code	Caption
	NA	Not Avail
15	VLO	Very Low
20	LO	Low
32	OK	Normal
40	HI	High
45	VHI	Very High
[Parsing]
logdata.LogDataSets
logdata.LogDataSets.CpuTime
logdata.LogDataSets.CpuTime.*Value	logdata.LogDataSet.t
logdata.LogDataSets.CpuTime.Level	logdata.LogDataSet.t
logdata.LogDataSets.CpuTime.Level.Code	logdata.LogDataSet.t
logdata.LogDataSets
logdata.LogDataSets.CpuTemp.*Value	logdata.LogDataSet.value
logdata.LogDataSets.CpuTemp.Level	logdata.LogDataSet.value	list:TempStatuses,2
logdata.LogDataSets.CpuTemp.Level.Code	logdata.LogDataSet.value	list:TempStatuses,1
logdata.LogDataSets
logdata.LogDataSets.CpuName.*Value	logdata.LogDataSet.name
logdata.LogDataSets.CpuName.Level	logdata.LogDataSet.name
logdata.LogDataSets.CpuName.Level.Code	logdata.LogDataSet.name
logdata.LogDataSets
logdata.LogDataSets.CpuUnit
logdata.LogDataSets.CpuUnit.*Value	logdata.LogDataSet.unit
logdata.LogDataSets.CpuUnit.Level	logdata.LogDataSet.unit
logdata.LogDataSets.CpuUnit.Level.Code	logdata.LogDataSet.unit
logdata.LogDataSets
logdata.LogDataSets.CpuvalueType
logdata.LogDataSets.CpuvalueType.*Value	logdata.LogDataSet.valueType
logdata.LogDataSets.CpuvalueType.Level	logdata.LogDataSet.valueType
logdata.LogDataSets.CpuValueType.Level.Code	logdata.LogDataSet.valueType
logdata.LogDataSets
logdata.LogDataSets.CpuDevice
logdata.LogDataSets.CpuDevice.*Value	logdata.LogDataSet.device
logdata.LogDataSets.CpuDevice.Level	logdata.LogDataSet.device
logdata.LogDataSets.CpuDevice.Level.Code	logdata.LogDataSet.device
This post has been edited 2 times, last edit by "Phatboy69" (Apr 10th 2013, 7:15am)
Phatboy69
Wednesday, April 10th 2013, 7:39am
Almost finished my new status page.
novax1
Wednesday, April 10th 2013, 7:46am
this is what I get.
Phatboy69
Wednesday, April 10th 2013, 8:07am
Maybe restart LCDHost or check your image map file. Make sure the short codes in your imagemap match the shortcodes in the datamap list.
