• 09.10.2026, 19:21
AE5probigNGslave
Somebody know how to export values ​​from aquasuite to OHM?
Tuesday, April 9th 2013, 9:42pm
or export all values (not only temperatures) from OHM to aquasuite? :?: :?: :?:
Thank you in advance for reply...
Namron
Tuesday, April 9th 2013, 10:20pm
Have a lookHERE & it may help you out :D
N.
AE5probigNGslave
Tuesday, April 9th 2013, 11:00pm
N.
It is not useful for me.I already read temperature sensors from OHM in aquasuite, but I need read RPM from bigNG through OHM. Any idea? ?(
Namron
Tuesday, April 9th 2013, 11:33pm
I don't think the Aquasuite will read RPM through it's "Software Temperature Sensors"...."Temperature" being the operative word here mind & not "RPM".. two different types of signals I believe... ;)
N.
Phatboy69
Wednesday, April 10th 2013, 6:33am
N.
There's currently no way to do this. You should replace the bigNG with Poweradjusts or an Aquaero. Aquasuite Software sensors only work with temperature.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
AE5probigNGslave
Wednesday, April 10th 2013, 10:01pm
N.
It is a pity. Currently I use the bigNG sensors through OHM for control of fans by Aquaero 5 Pro. BigNG is slave. BigNG was assimilated........ :D
