• 05.10.2026, 14:54
cincilleo
Aquaero 5 lt mps sensor question for shoggy
Friday, April 19th 2013, 2:21am
Hi i bought aquaero 5 lt and mps 400 sensor...
I need the water temperature for setting the curve of rad fans, but i can read the temperature only in the mps menu
How i can use the mps water temperature sensor in the aquaero fan settings?
Thank you
cincilleo
Friday, April 19th 2013, 2:34am
And i cannot use the flow rate for setting things in the aquaero device menu :|
cincilleo
Friday, April 19th 2013, 4:09am
All fine.. my mistake i connect the aquabus cable to flow port :| now it's all fine...
But it's possible that i have 399 lt/h at 85%, with a laing 500- 18 watt with xspc top?
Loop is:
Pump--->2 heatkiller gpux waterblocks (with sli gpu multi-link heatkiller)--->>ek supreme hf---->280rad---->reservoir xspc
cincilleo
Monday, April 22nd 2013, 11:24pm
No one can tell me if everything is ok?
Nihil Simile
laing
Tuesday, April 23rd 2013, 2:37am
I have the Laing Plus 1 rated 600Lh and in a simple test loop it was running @ 400Lh, so the flow looks normal at least from what I have seen with my pump.
Jakusonfire
Tuesday, April 23rd 2013, 9:57am
Loop is:
I'm not sure what you mean by a Laing 500 - 18 watt ?
Anyway 399lt/h is extremely unlikely through any loop except one with no water blocks. I have two pumps pushing through 2 blocks and flow is only 250lt/h ( Measured by the old fashioned mechanical flow meter )
I would suggest you have not configured everything correctly.
cincilleo
Tuesday, April 23rd 2013, 12:04pm
Ok but... mine is three blocks and a rad loop... It's a simple loop?
Loop is:
What i need to configure? There are preset settings on aquasuite... Maybe is the flow mps sensor before the reservoir the issue?
mandrix
Tuesday, April 23rd 2013, 12:39pm
399 lph = 1.7556 US gpm (399 * .0044) which seems pretty high to me but may be possible.
When my loop was smaller I could get 1.7 gpm but that was with a dual MCP35x pumps setup.
Nihil Simile
Lh
Tuesday, April 23rd 2013, 7:18pm
I may have misunderstood, I thought your concern was the pump was putting out far less than the rated 500 Lh. I use the High Flow sensor when I set it @ 70% it will show mid 200 Lh, it is calibrated in the Aquaero 5 XT menu High Flow.
cincilleo
Wednesday, April 24th 2013, 1:30am
I don't know... Maybe it's important where is placed the mps sensor?
Maybe near the pump show an higher value?
cincilleo
Thursday, April 25th 2013, 2:22pm
up
cincilleo
Friday, April 26th 2013, 2:45pm
i Changed the disposition of the loop... But the things are the same
Always 400 lt/h... I think it's impossible...
Someone have other calibration settings for mps 400 sensor?
Jakusonfire
Friday, April 26th 2013, 4:12pm
I don't have a pressure based flow meter to experiment with but as I understand it there is a button on the MPS config tab to set the current flow as zero. Unplug your pump for a couple of seconds, hit the zero flow calibration button and plug the pump back in.
Namron
Friday, April 26th 2013, 4:25pm
You may have already looked into this, But.... What diameter is the tubing your using?..... Because you need to use the little "Diffuser Plate" for tubing that is smaller than 13/10mm when using the 400 variant.
For the 200 variant you need the diffuser plate for tubing that is smaller than 10/8mm & 11/8mm. The only time you don't use the diffuser plate is when you have the 100 variant...
Also make sure you don't have any angled fittings connected directly to the Sensor, It needs to have straight fittings so there is no distortion to the flow of the fluid before it enters the Flow Sensor..
N.
cincilleo
Friday, April 26th 2013, 4:46pm
I have done the zero calibration
N.
I have no diffusor beacause i have 10/13 fittings (3/8) and mps 400...
How i can check if my mps is really the 400 and not the 200? Maybe the shop sent me the wrong item...
cincilleo
Friday, April 26th 2013, 4:48pm
Sorry i've read on the flow meter... is the 400...
I don't know what i can do for an accurate reading...
It's very bad that you spend almost 150 euro in controller and sensor, and they won't work
Namron
Friday, April 26th 2013, 4:55pm
Sorry.. Not sure then.... I had no issues with my two 100 variants, I just selected the correct setting for my sensor from the drop down menu in the configuration menu & clicked on the import sensor data & it was set up..
Don't know if maybe connecting it first to the flow header has somehow damaged it?... don't even know if that is possible to cause any damage from the flow header?....
N.
cincilleo
Friday, April 26th 2013, 5:18pm
Here is a video...
It's possible that the flow is 400 lt/h?
http://www.youtube.com/watch?v=pEXQlVLXiU0
Namron
Friday, April 26th 2013, 5:27pm
That certainly looks to have a fair amount of flow for sure, but it's difficult to say from just a vid... If you had a mechanical flow meter one, you could try in the same loop, It probably wouldn't give the exact reading as the MPS sensor but should be within a few L/h to give a rough idea if the MPS is somewhere reading correctly or not.. Sorry can't think of many other options as you say you've set it up correctly e.t.c It should work..
N.
cincilleo
Friday, April 26th 2013, 5:36pm
No other mechanical sensor available here...
Thank you anyway
