• 05.10.2026, 22:31
Jakusonfire
Friday, April 26th 2013, 7:20pm
A Laing 355 18 watt pump can generate 1.65 PSI at around 400LPH, a low restriction CPU block like a raystorm generates more restriction than that at 400LPH.
Unless you are running only a CPU block with the pump, you are not getting accurate results.
cincilleo
Saturday, April 27th 2013, 12:42pm
http://www.ybris-cooling.it/laing-pompa-p-2984.html
Is >900lt/h and 5,7 meters headpressure
Not the same model that you are talking
Jakusonfire
Saturday, April 27th 2013, 4:57pm
This post has been edited 2 times, last edit by "Jakusonfire" (Apr 27th 2013, 5:01pm)
cincilleo
Saturday, April 27th 2013, 7:28pm
ok
