• 01.10.2026, 15:22
Psychor
MPS 400 & AQ5 Pro Settings?
Saturday, April 27th 2013, 4:28am
I have my MPS 400 connected to my AQ5 Pro (1030) via the Aquabus. The MPS is detected in AS2013 as Flow 11.
What does "Digmesa" means and what do the various values mean? What should the MPS be set to? I have 1/2" ID 3/4" OD fittings connected to the MPS.
Thanks.
Psychor has attached the following image:
Saturday, April 27th 2013, 7:05am
This settings not relevant for the mps.
The mps output also scaled values. This setting has no effect.
Psychor
Saturday, April 27th 2013, 7:07am
Thanks Sebastian. What about "minimum" and "maximum?" My "maximum" is set to "39.6" yet the MPS reports 89 Gal/hour (I use gallons, not liters) which sounds about right.
This post has been edited 1 times, last edit by "Psychor" (Apr 27th 2013, 8:57am)
Saturday, April 27th 2013, 8:56am
this is the scale in the lcd when you display the bars.
Psychor
Saturday, April 27th 2013, 8:57am
Thanks again Sebastian.
