• 30.09.2026, 00:31
Psychor
MPS 400 Internal Temp. Sensor?
Saturday, April 27th 2013, 9:04am
All hardware and fans in the PC are off (including pumps) except the AQ5 Pro. All case side panels are off.
Ambient room temp. = 23C
MPS 400 internal temp. probe = 27C
Delta = 4C
Is such a difference typical? Should I just set the MPS internal temp. in Aquasuite = ambient room temp and be done with it?
Thanks.
_KaszpiR_
Saturday, May 4th 2013, 7:55pm
I suggest leaving the computer off overnight so the temperatures will stabilize.
You may alos turn off computer, leave pump and fans to on at full speed and then try to cool down to the ambien tmeperature.
Then turn off the fans and pump and wait till it stabilize.
Second, check out also with external sensors, some may also have wrong offsets (so use two or three, and calculate average).
Psychor
Sunday, May 5th 2013, 2:07pm
Good suggestion! It appears that the difference isn't as bad as I first thought - the MPS is still off but about +1.2C.
I'm using a standalone external temp. sensor and two AQ temp. probes to measure ambient.
This post has been edited 3 times, last edit by "Psychor" (May 5th 2013, 2:29pm)
_KaszpiR_
Sunday, May 5th 2013, 10:02pm
Then go and adjust the offset :)
Psychor
Sunday, May 5th 2013, 10:10pm
Yup. That's what I did. :thumbsup:
Jakusonfire
Monday, May 6th 2013, 10:29am
This is a good read for anyone with an MPS sensor
http://www.xtremerigs.net/reviews/access…00-flow-sensor/
mandrix
Monday, May 6th 2013, 12:26pm
Thanks for that link, Jakusonfire. Very good read on the mps sensor and answers some questions I've had. :thumbup:
Similar threads
