• 01.10.2026, 18:39
Barney Gumble
Aargh. M4 screws please.
Tuesday, April 30th 2013, 2:07pm
I have bought the D5 pump adapter & Aqualis reservoir. D5 mounted on adapter with included countersunk M4 (x 12mm, I think) screws. This assembly is called to be mounted on the reservoir with the same size screws and there was only the one set!
Where or how can I get more? No WC online store I can find sells them.
Thanks.
Jeremy
RE: Aargh. M4 screws please.
Friday, May 3rd 2013, 9:30am
Barney Gumble
Friday, May 3rd 2013, 3:01pm
Believe it or not I did try that.....and didn't find any countersunk versions. However your search did so thanks! :thumbup:
Similar threads
