• 23.11.2026, 19:45
balizeiro
Aquaero 5 LT and profile load in Alarm Actions
Friday, May 3rd 2013, 8:05pm
I already saved several profiles (to .pro file), but I don't know how to associate them with profile 1, 2.... so that I can use them as actions for the alarm settings.
Can I specify profiles with Aquaero 5 LT, or not? If yes, how?
Thanks in advance
Friday, May 3rd 2013, 11:18pm
Profiles not available for aquaero 5 lt.
balizeiro
Saturday, May 4th 2013, 1:06am
So I can't change profiles in Alarm Actions?
Or is there any other way to set it?
Is it planned to be possible to set it in the future?
EDIT: Because what I need is to change the speed of my pump if the flow drops below a certain value
This post has been edited 1 times, last edit by "balizeiro" (May 4th 2013, 2:55pm)
balizeiro
Friday, May 10th 2013, 8:37pm
Anyone? ;(
Grasshopper
Saturday, May 11th 2013, 1:30am
With the AQ5 Pro in alarm actions page of aquasuite, I can add the action "load profile1", or load profile 2 etc
can you?
This post has been edited 1 times, last edit by "Grasshopper" (May 11th 2013, 1:49am)
balizeiro
Saturday, May 11th 2013, 9:12pm
I can load a profile as an action for an alarm, the problem is that I can't specify what's profile 1, 2....
This post has been edited 1 times, last edit by "balizeiro" (May 12th 2013, 12:25am)
arad85
Wednesday, May 15th 2013, 10:00am
Hello all, first post.
I have the same problem too (I'd like to set fans to 100% on an alarm) so would like to add it as a feature request for LT users....
This post has been edited 1 times, last edit by "arad85" (May 15th 2013, 10:20am)
Jeremy
Friday, May 17th 2013, 3:42pm
This is interesting. I thought the LT was everything the XT was (identical control board), so why is this feature not available? Is it simply for product differentiation, or can we hope that the feature will be enabled at some point?
"Please note that at present not all functions are available for the aquaero 5 LT. If you want to use specific functions and you are not sure if they have been already integrated to the aquasuite 2012 software, please contact our support."
That's all the product description provides. Are there any other XT features that are not available on the LT?
Grasshopper
Saturday, May 18th 2013, 12:26am
AS2013 only works with 1 profile, if AS had tabbed profiles you would not need a switching mechanism to access other profiles.
Perhaps the limitation of the AS running real time.
balizeiro
Saturday, May 18th 2013, 1:38pm
... you would not need a switching mechanism to access other profiles...
A button/tab/radio button/check box.... in the interface???
