• 07.11.2026, 05:20
Grasshopper
CPU and memory usage for AS2013
Tuesday, May 28th 2013, 3:40am
what is considered normal usage?
starts off:
CPU usage 1% memory usage 91 MB
after 12 hours:
CPU usage 13% memory usage 246 MB
turning off desktop display:
CPU usage 0% memory usage 206 MB
CPU usage of 13% prevents the CPU entering the lower power state, and I really don't want my computer idling at full speed
This post has been edited 2 times, last edit by "Grasshopper" (May 29th 2013, 2:27am)
Jeremy
Wednesday, May 29th 2013, 4:46pm
It's been an ongoing issue/bug for a long time now, it's getting slowly better but isn't resolved.
There's no avoiding it if you use the software. The only solution is to close the software and then re-open it when it starts becoming an issue. Luckily, the software isn't required for the hardware to run properly, the software is only needed to make modifications and monitor things once everything is written to the device.
_KaszpiR_
Saturday, June 8th 2013, 12:29am
Try to remove graphs, or do not set them over 15 min.
Grasshopper
Saturday, June 8th 2013, 1:03am
I have set up a task schedule to close and reload aquasuite every 3 hours,
So its the graphs that are the issue, perhaps if the problem is known they are getting closer to resolving it
Psychor
Sunday, June 23rd 2013, 10:32pm
Good idea.
