• 23.11.2026, 00:18
blackd834
SLI watercooling bridge
Thursday, June 6th 2013, 8:21pm
I got the Aqua ComputerTwinConnect 2-Slot the other day with aqua Computer AquagraFX - GTX 680 Water Block and it was leaking I have tryed many times to fit it but still leaks. The 0-rings that come with the water block look smeller then the ones i got with the twinconnect and mayb bad anyway where can i get more 0-rings that will fit? The 0-rings i need are the ones that go from the water block to the Aqua ComputerTwinConnect 2-Slot.
WoodSpoon
Friday, June 7th 2013, 7:09pm
Might be worth going to your local plumbers or builders merchants with the O rings and fittings to look for something that fit's better or ask a ask a service assistant for something suitable.
