• 30.10.2026, 05:20
bloodyshogun
Dimensions of AMS 140mm
Tuesday, June 18th 2013, 7:42pm
Do you have a diagram with the exact dimensions of a single AMS 140mm unit?
I am trying to build this into an ITX build and will be very tight on space.
I understand the unit will be 146mm x 184mm x 63 mm. My question is, on the long side (the 184mm one), how far out will the unit extend from the fan mounting?
4WDBenio
Wednesday, June 19th 2013, 6:09am
Hello Bloodyshogun,
I am a newbie... but hopefully this helps:
Are you referring to running an AMS140 with Pump Module or without the Pump Module?
If running it without the AMS Pump Module ...then the AMS140 will be as long as you have stated.
AMS140 = 140mm+44mm = 184mm. No longer and no shorter.
Source of my Reference:
New radiators: airplex modularity system
If running an AMS140 WITH Pump Module then yes it will be longer. You have two PUMP options with AMS... Compact 600 vs D5. Pump Module adds additional length, and depending on pump also effects a measurements.
For example: Compact 600 does not add length on the Pump Module, but it does add more thickness (Sorry prob wrong terminology). D5 will add additional length on the Pump Module. PUMP Module itself only adds the same thickness as a 25mm think FAN so it will be flush in thickness with Mounted Fan.
So Question is: Are you looking to run your AMS140 with a Pump Module? If Yes then you need to add more length into the calculations. PLUS add in the PUMP Calc.
Hopefully this helps a little bit. No Technical Manuals anywhere...I have searched high and low...
I am sure a senior member on this Forum will have better insight than I.
Cheers,
bloodyshogun
Wednesday, June 19th 2013, 4:25pm
Thanks, I am trying to run it without the pump module, but probably still running within 5mm margin of error in whether the radiator will fit. It's unfortunate that I can't find any diagrams....
It's going to be a small build, Going to use an Swiftech Apogee Drive II and a closed loop design to save space as well (will be using swiftech's new, shorter quick disconnects to fill / bleed air).
4WDBenio
Monday, June 24th 2013, 12:01pm
Ive been looking for drawings... here attached is not an AMS140, but it is a drawing of an AMS240! Therefore you might be in luck to find a AMS140... I hope you do. :-)
4WDBenio has attached the following file:
Similar threads
