• 21.11.2026, 11:54
pitahbread
Need assistance with High Flow Meter USB Setup.
Sunday, August 4th 2013, 2:52am
Hey guys, I've been attempting to setup my High Flow Meter USB with no success. I have it hooked up by USB at the moment but I cannot seem to get it to show up under the "sensors" tab under aquaero.
The flow rate and internal temperature sensor seem to be working in the second picture in the alarm configuration tab.
Thanks for all your help.
This post has been edited 2 times, last edit by "pitahbread" (Aug 4th 2013, 2:54am)
Grasshopper
Wednesday, August 7th 2013, 10:59am
think you will find it is the MPS
pitahbread
Thursday, August 8th 2013, 1:49am
Do you mean I have to switch the device to "Flow sensor mps flow" instead of the "Flow sensor high flow usb?"
pegleg
Sunday, August 11th 2013, 10:56pm
i cant seem to get mine to show up either,that how it looks on mine to
pitahbread
Sunday, August 18th 2013, 3:16am
Hm I'm assuming you just left it alone?
pegleg
Sunday, August 18th 2013, 3:30pm
no i want to fix it and for it to do what it should..lol
pitahbread
Monday, August 19th 2013, 7:06am
Fair enough. I'm going to reset the High Flow USB Meter back to factory defaults and wire it up again, I'll get back to you on how that works out.
pegleg
Monday, August 19th 2013, 6:37pm
i have tried all that dont know what too do or why its not showing up as flow 11 just flow 1 flow 2 thats all thats shows up i had it working before i did my rebuild.
Could are aquaero5 be messed up?
This post has been edited 1 times, last edit by "pegleg" (Aug 19th 2013, 6:39pm)
pitahbread
Monday, August 19th 2013, 9:22pm
No clue, mine doesn't even show up as Flow 1 or 2 =\.
pegleg
Wednesday, August 21st 2013, 1:49am
i just did mine again. i don't know what is wrong with it either,I see the 1and 2 flow but no flow 11
pitahbread
Thursday, August 22nd 2013, 2:08pm
So I reset my High Flow Meter USB back to the factory default but nothing changed but I realized that I don't even have the option to set my flow sensors to the correct flow meter.
If you look at the options I have it only displays the older High Flow sensor(53068,) not the USB one which is manufacturers code 53129. This is also after selecting "Flow sensor high flow USB" in the configurations tab under MPS.
Are you having these issues as well?
Jakusonfire
Friday, August 23rd 2013, 5:09am
Those settings don't change anything anyway. They are just the default pulse count but the USB flow sensor does its own processing. changing the pulse count number does not do anything, it is only for the older sensors.
It sounds like fully resetting the Aquaero and reinstalling Aquasuite is all there is left to try. It seems like either the Aquaero or Aquasuite is confused because it should not show those extra flow sensors 4, 5 and 6 unless you have renamed them to that, or you have poweradjusts connected.
This post has been edited 1 times, last edit by "Jakusonfire" (Aug 23rd 2013, 5:14am)
pegleg
Friday, August 23rd 2013, 5:32am
I had a power adjust 2 on mine but, i never got it to work so i just took it off.all i get is the flow 1&2 no 11
how do i do a hard reset on the aquaero 5?
pitahbread
Sunday, August 25th 2013, 3:00pm
I do have 3 Power adjust 2s connected along side my Aquaero 5 Pro. Should I still fully reset my Aquaero and re install Aquasuite?
pegleg
Monday, August 26th 2013, 5:26pm
i guess nobody can help us with problem and nobody can tell me how you do a hard reset on the aquaero 5 xt. theres noway to reset the aquaero 5 xt without the software like on my aquastream xt pump u take and put black piece they give u on the temp sensors and it resets it.
Namron
Monday, August 26th 2013, 9:15pm
Have a look HERE Scroll to the end & there you will find a quick guide to doing a hard Reset for the Aquaero 5 (It's the same for all variants of the Aquaero)...
N.
pegleg
Thursday, August 29th 2013, 7:09pm
ok,thanks alot
pegleg
Friday, September 6th 2013, 4:49pm
well,i did a hard reset and i still can't get the flow to show up.i guess i will have to buy the new 6 when it comes out because something is wrong with the aquaero 5 or the flow meter
pegleg
Sunday, September 22nd 2013, 5:04am
when i plug my aquastream xt pump in when i first start computer it will say found new hardware but when the flow sensor plug in all by itself it will not say this so can the flow sensor be bad?
pegleg has attached the following image:
Similar threads
