• 07.10.2026, 12:32
SverreMunthe
Temperature readings fluktiating too much
Sunday, August 4th 2013, 8:56pm
3 of my temp sensor readings are fluctuating too much. 1 and 8 on the Aquaero 5XT and one of my Poweradjust 2's. The Last one is room temp reading. The 2 others are before and after the radiators. The rest of the readings trough the water loop are stable.
A usable fix for this problem would be to make it possible to take readings over time, ie. average over 1 sec and up to maybe 60 secs. This should be available anyway and shouldn't pose much of a problem for your developers.
Monday, August 5th 2013, 1:54pm
This is not possible since it is way too complicated to implement and costs an unnecessary amount of processing power. Keep in mind that everything is done by the aquaero and the software is only a user interface.
SverreMunthe
Monday, August 5th 2013, 5:56pm
This shouldn't take much prosessor power. You're already well on the way with a chart. The only thing extra you need is to sum the last x number of seconds and divide by x. If you're not a programmer and they tell you it's complicated, tell them they're full of shit. ;)
