• 09.10.2026, 02:58
SverreMunthe
Tubemeter
Sunday, August 4th 2013, 9:03pm
Why isn't it possible to see the tubemeter in Aquasuite under aquaero 5, together with all other sensors?
I have probably broken both of mine by connecting them the wrong way, but when you buy both the meter and the cable from Aquacomputer, and both are made by Aquacomputer, wouldn't it be great if it was impossible to make a wrong connection?
Please make some longer ones as well, there are those of us with larger reservoirs. And I might be crazy wanting to connect one to a 250mL reservoir, but half the fun with Aquaero is all the stuff you can connect to it and play with. My PC is for gaming AND playing around with Aquaero!
Thinking about buying a water pressure meter next, just hope it's possible to see that in Aquasuite as well.
Monday, August 5th 2013, 1:53pm
The tubemeter is visible in the aquaero directly and also in the software when connected via aquabus. It only depends on how you setup everything. If it is only connected via USB you have to use the aquasuite 4.72 since the current aquasuite does not support the tubemeter (via USB).
The connection cable is not available in longer sizes because the aquabus is very sensitive to communication errors. You can extend the cable yourself but be aware that with a too long cable the sensor might not work correctly.
The tubemeter is also a discontinued line so there will be no larger variants available. Its successor - the mps sensors - is much more flexible to use.
