• 16.11.2026, 02:21
KiLouNo
Advice needed
Friday, August 9th 2013, 1:36pm
Hello,
I plan to make my first WC, with 2 loops and Aquaero 5 XT for controlling. I read a lot of guide from Namron, so i think i know the essential about the system (4 MPS max, 1,65A per fan channel... etc).
I just want to be sure that my aquaero 5 configuration will be correct. Here is my build :
- 12x 120mm fans (Corsair SP120 HP), 0.18A each according to spec -> 2.16A -> 2 channels
- 3x 80mm fans (Enermax UCMA8 Magma), 0.25A each according to spec -> 0.75A -> 1 channel
- 2x D5 MPS pump with USB and Aquabus
- 2x MPS400 flow meter
- 2x inline water temperature sensor
I would like to install them like this
Can you please tell me if this is correct ?
Thanks a lot !
This post has been edited 1 times, last edit by "KiLouNo" (Aug 9th 2013, 1:42pm)
Grasshopper
Wednesday, August 14th 2013, 1:34am
looks good for 2 loops, I am assuming you are using the mps temperature sensor as either in or out side of radiator, so placement of device is important.
Similar threads
