• 12.10.2026, 19:53
zarabatana
Information about airplex GIGANT 3360 and another information to build a VCL Cluster
Monday, August 26th 2013, 10:09pm
Hello,
I'm looking for information about airplex GIGANT 3360.
Can you tell me about maximum heat dissipation?
What do you recommend to do pair with it?
I would like to build a VCL cluster with this specs:
My Broker Node have this configuration:
# 4x ATI 7990
# 2x Xeon E5-2687W
My Compute Nodes will be the same, but with 2x Xeon E5-2680.
My question here is: what AC parts I will need to cool this down?
I will buy, per node:
# 4x kryographics for HD 7990 and FirePro S10000 (p.n: 23570)
# 2x cuplex kryos HF for Socket 2011, G1/4 (p.n: 21586)
But, what you recommend to cool this system?
I would like to build a HF WC.
And no, I will not do any kind of Extrem OC, so I will not use DICE, Liquid Nitrogen, etc.
I just need a WC system quiet and high efficient.
Thank you for your time and attention.
Many regards.
This post has been edited 2 times, last edit by "zarabatana" (Aug 27th 2013, 12:09am)
Pilo
Tuesday, August 27th 2013, 1:24am
To your first Question. It was mentioned in a past thread that a GIGANT 3360 could dissipate up to 10.000 Watts of heat with a good fan cooling. If I remember right.
zarabatana
Tuesday, August 27th 2013, 2:34am
Thank you for your fast replay Pilo.
I searched here and do not found this information.
Even on google, I can't found it.
Will be very nice, if AC just post all information about there own products.
It is very "strange" have to dig for an information, because the manufacture do not publish it.
Of course, AC have the best WC (IMHO).
I really would like to build my WC system with AC. I just need the information.
Many regards.
Tuesday, August 27th 2013, 4:46pm
Airplex GIGANT 3360: 6.000W
Airplex GIGANT 1680: 3.000W
Both values are based on a temperature difference of 15°C between the cooling liquid and the environmental temperature. Of course the wattage will rise or fall with different temperature differences which is the reason why you not really provide a general value.
